Results 1 to 10 of 23
December 19th, 2003 12:39 AM #1
hey guys. i recently had my PMS.
ito ay para sa xwind. usually, before nilagay ko 4.5 liters lang. pero now sabi sa akin ng shop na 6 liters daw dapat ilagay ko para sa 2.5L engine. eh una 4 liters lang binili ko. napabili pa tuloy ako ng extra 2. so bale 6 na lhat. nung nilagay 6 liters.... sobra pala! its way over the measuring level. mga half inch more.
so guys, ok lang ba ang sobra sa engine oil?
sayang nga eh. nanghihinayang ako. ang binili ko pa naman ay Petron revX all terrain * 274/ea. lumaki tuloy gastos ko.
December 19th, 2003 12:57 AM #2
It's bad because it will cause the oil to foam resulting in less lubrication than if it was at the correct level.
December 19th, 2003 01:02 AM #4
Subukan mo uminom ng foam ng frappucinno. Nakakawala ba ng uhaw? Hindi, diba. Kasi puro foam lang. Ganon ang nararanasan ng makina mo ngayon.
- Jul 2003
- 58
December 19th, 2003 09:11 AM #6Actually if its not too much, i dont think it will harm your engine. I usually put more oil past the dipstick on my trick FJ, this to have more oil when i'm driving at extreme angle.
If you want to drain it, just remove the drain plug under the oil pan.
December 19th, 2003 10:30 AM #7
Which Isuzu casa recommended that??? Inteco ba yan? I suggest you let them drain the excess, and refund your money.
OT: "i recently had my PMS." -- doesn't sound too good. Images of my cranky wife suddenly flashed before my eyes... ;)
December 19th, 2003 11:01 AM #8
The answer to that DIESELNUBI
Like LORD OTEP and LORD GLENN said " NO "
4ja1 ENGINES pag di palitin ang oil Filter can go as high as 5 liters pero pag 4 Liters pwede na yan
I drain mo tapos... throw it in there face.... hehehehe
December 19th, 2003 11:48 AM #9
bad! talaga itong is boknoy! hehehhe
pansin ko pag sobra langis ko mas mausok sya kesa dun sa me bawas ng konti sa full
December 19th, 2003 02:25 PM #10
Lunod ang makina, mahihirapan lalo umandar. Just follow the drain plug procedure and estimate a liter off.
high idle RPM at engine start
