Results 1 to 10 of 11
- Apr 2008
- 14
April 18th, 2008 09:47 PM #1Help naman po with my Mits GLXi 94 matic- excessive black smoke at mahina po humatak pag nkabukas ang aircon. Sbra lakas din sa gas 5 km/l lang ave ko. Nanginginig din sya pag nkaon aircon pero pag wala aircon ok naman sya. Ano po ba dapat ko pagawa? Help naman po.
April 19th, 2008 10:40 AM #2
Bro, my suspicion is that your car is running with super rich air/fuel ratio. the black smoke is caused by unburned fuel. It can be that there's something wrong with your EFI needs or maybe your air filter is so clogged that your air intake is being choked, thus comsuming a lot of fuel. just my two cents.
- Apr 2008
- 14
April 23rd, 2008 08:35 AM #3ano po dapat ko pgawa d2 sir. Sabi kc sa casa palit daw servo un ba tlga cause nun. Tnx
April 28th, 2008 07:29 AM #5
Hi...
Black Smoke (too much Gas - unburned)
White Smoke (too much Oil - unburned)
Grey Smoke (too much of both - unburned)
Your car is using too much gasoline...
Your engine management system or computer is telling your injectors to inject more gasoline than the usual 14:1 air to fuel ratios.
What are the possible reasons why your engine computer is doing this?
1. Oxygen Sensor (defective) - Your Oxygen Sensor tell the amount of oxygen coming in to your engine... if this is not telling correctly... then your computer will not give the correct ratios of fuel to your engine.
2. Clogged Air Filter Elements... - well, you need to clean them often. When the filters are clogged, therefore, not enough air or oxygen is able to get inside your combustion chamber, therefore - you will have more fuel than air... resulta - black smoke.
3. Foul Spark Plugs - If your candles are not strong enough enymore.. then chances are - you will have weaker combustion... since our gasoline are slow burning fuels... a strong igniting spark plug will make it burn faster. (secreto ng mga kumakarera)
With the above items... you will be able to see where your problem is coming from.
REMEDIES for Do it Yourselfers:
1. Replace or Service your O2 Sensors. (Madugo ata ang presyo nito... if your need to replace it). If you buy an EFIE (EFI enhancer)... you will spend also... but, you can control the fuel and air mixture to your discretion... and you can have the option of running more leaner mixture... a must in todays cars para makatipid. and Lastly, the most economical way... is to wrap Aluminum Foil around the sensors... normally you will find one sensor the exhaust manifold... balutan lang ng Alum foil.. tie it up with copper wire... at least mga 5 layers... this wil heat up the O2 Sensor, and will fool your engine computer - telling it to reduce injecting gas. Because a heated up sensor means... there is more Oxygen in you engine, therefore, the injectors need to put lesser gasoline.
2. Clean your filters... better, replace it with velocity or ram flow stacks... or pipe.. (shimota, Iceman or Local). This will provide more ir into your engine... and will mean lesser gasoline.
3. Replace your spark plugs... or treat it with NewOil... so that it will be Carbon Deposit proof... Carbon Deposits stick to our plugs like cement... when this happens.. hihina ang spark nito. Not unless you protect it with NewOil... it is a metal treatment that cleans and protects your plugs from carbon deposits. Kahit basain mo spark plugs with NewOil - gagana pa rin ito. (My secret in Racing. since 1996)
I hope the above tips helps and enlighten.
Tsikot Member Rank 5
- Nov 2003
- 3,848
April 29th, 2008 07:23 AM #6have it MUT'd in casa, mura lang naman. check if there is anything wrong with the maf and servo. normally those 2 will cause the problems you mention.
- Apr 2008
- 14
May 5th, 2008 11:20 PM #7sir napa mut ko na po nid daw po palitan ang servo. Just want to make sure na un nga ang sira ng auto mejo mahal po kc e. Will it improve my fuel economy? ano po ave FC ng glxi 94 matic? May ntingnan na ko mitsu prim 6500 brand new servo + 1k labor. Ok na ba un? Tnx!!!!!!
- Nov 2003
- 3,848
May 22nd, 2008 09:40 AM #9
Medyo cheap na nga 6500. Other stores sell it for twice the price.
Try getting a second opinion from highly recommended Mitsu mechanic Raymond Sarol (search mo na lang contact details nya sa tsikot). He might be able to repair your servo.Last edited by JohnM; May 22nd, 2008 at 09:42 AM.
- Apr 2008
- 14
May 22nd, 2008 11:32 PM #10more inputs naman po before ko finally pagawa ang auto jaz want to make sure na mgiging ok sya after pgawa. TNX!!!!!!!!!!
San mo nabili?
Fire Extinguisher for Car: what brand and type...
