Results 1 to 10 of 11
- 25
May 7th, 2008 09:27 AM #1Tsikoteers,
Ask ko lang if what would happen if I use pure concentrated coolant in my radiator? Yung walang halong tubig. Thanks.
May 7th, 2008 09:39 AM #2
bro, it would depend on the brand of coolant that you will use. some brands like prestone do not need a mixture of water with it, but some other coolants would require you to put it in with a 1:1 mix of pure distilled water.
i really don't know what are the effects but these are what i can think of:
1. each specific engine is differently designed to work on optimum at a certain temperature. by adding coolant lang, baka the engine can work overtime to compensate to reach that specific temperature;
2. coolants alone may not properly absorb and transmit heat to work at that optimum temperature. water can do that. by doing this, it may lead to overheat because of improper heat transmission and circulation.
here is an article i got over the internet...
At temperatures below the boiling point of water, water is more effective at absorbing and carrying heat than any mixture of water and either ethylene glycol or propylene glycol. If you have a 160 degree thermostat and your cooling system is functioning well, you could theoretically add cooling capacity by replacing your water/antifreeze mixture with pure water.
But the added cooling capacity would be short lived indeed. Adding antifreeze gives the following benefits that water alone cannot:- Higher boiling temperature at a given pressure
- Lower freezing temperature
- Corrosion resistance
Always know what you're using for coolant. If you know there's no propylene glycol in the coolant mixture, you can use a simple specific gravity indicator to deduce your mixture. The ideal mixture is 50/50, but in extremely cold climates you can get by with 70% antifreeze and 30% water. Any more antifreeze will lead to overheating.
let's just wait for the opinion of the other guys here.
May 7th, 2008 10:17 AM #3
Tataas ang boiling and freezing point… no critical effect….only the cost
mas mahal ang concentrated kaysa 50/50 prediluted.
prestone has concentrated and ready to use coolant - just like the one i got from gaby dela merced promo.
May 7th, 2008 11:23 AM #4
May 7th, 2008 11:41 AM #6
It's been discussed in-depth before.
See this link:
http://www.jcna.com/library/tech/tech0011.html
Tsikot Member Rank 4
- Jun 2006
- 2,605
May 7th, 2008 11:48 AM #7AFAIK, no engine and coolant manufacturer recommends the use of pure coolant.
- Feb 2003
- 324
May 7th, 2008 12:55 PM #8I tried it before in an old car, by accident. with full load of passengers hindi tumaas ang temp gauge, below minimum recommended operating temp.
Tsikot Member Rank 5
- Nov 2003
- 3,848
May 22nd, 2008 09:10 AM #9why would you even want to try this? it's not recommended so don't do it.
May 23rd, 2008 07:23 AM #10
Taguig shouldn't be blamed over cancelled Makati Subway System -mayor | GMA News Taguig shouldn't...
Makati Subway. Completion date: 2025
