Originally Posted by
zap.FREEDOM
just a recommendation, since your aux fan is wired directly at the ignition switch (which tends to start operating once the ignition turnon) instead of wiring it into the ignition switch, re-wired it and put a separate switch, so that you can turn it on and off on times its just need to be operate. yung akin nakaganyan, may switch siya, so kapag half na yung temperature gauge ko dun ko lang siya bubuksan then pagbumababa,...papatayin ko na ulit...pangit kasi nakarekta,
but toyota outfits their cars with locally manufactured yokohamas. i just follow suit. after many...
Finding the Best Tire for You
