Results 1 to 4 of 4
- Jan 2010
- 55
March 7th, 2011 11:42 AM #1I need help on my Honda Civic 96 (matic) engine leak. Lahat ng shafts napalitan na ng bago (which actually stopped the leak on left side of the engine). Yung gasket din napalitan na ng bago (wala na din leak). I already came back twice sa shell for a back job sabi wala na daw leak at hindi ko na kelangan bumalik. But i noticed may nagle-leak sa bandang right side, it's coming from the top. Ayaw ko na bumalik sa shop mukhang hindi magaling ang mekaniko.
Meron ba kayong alam na shop kahit sa north to have my engine leak fixed? Nakaka frustrate na tong leak, palitan ko na kaya engine ko? Anong shop ang marerecommend nyo? Wag sa casa kasi mahal.
Baka i need to have my engine replaced. Pa advise naman.
March 7th, 2011 12:52 PM #2
have the PCV valve checked, cleaned or replaced if it is not doing its job anymore. maybe you have too much crankcase pressure that has not been relieved by the PCV. you mentioned about a new valve cover gasket, has the tech applied RTV sealant on the corners of the neoprene gasket where it meets the half moon plugs or seals? the gasket will leak if the mating surfaces were not clean and dry when the gasket was replaced
- Jan 2010
- 55
- Jan 2010
- 55
March 13th, 2011 12:21 PM #4Anyone meron bang nakaka alam na marunong mag repair ng engine leak sa south area? I need to have this repaired asap.
Xiaomi E-Car
