Originally Posted by
7138
MT ba ito sir? if it is, pakiramdaman mo, pwedeng nagsisimula ng dumudulas ang clutch.
if AT, paflush mo ATF, then fill in fresh batch.
distributor-less engines doesn't need to be manually adjusted, wala ka ng gagalawing distrubutor for the timing.
the ecu will automatically adjust by itself.
the least TS can do is, reset the ecu.
Replaced with the Pilot Sport 5 na ata, but the available sizes aren't yet as broad as the PS4.
Finding the Best Tire for You
