Results 1 to 10 of 24
- Oct 2008
- 380
May 30th, 2016 07:38 PM #1tanong po. me 2007 1.3L na Avanza.
usual city driving lang po.
nong last week, nag punta kmi meycauayan, parang ok naman takbo kahit mga 90kph.
nitong weekend, pumunta kami pansol calamba. napansin ko pag mag 80kph na takbo ko parang kinakapos. tapos pag paakyat, dapat mga 60kph lang tabko ko.
ano kaya problem? kakatapos lang ng 70km PMS ko sa toyota (abt 3 weeks ago) and wala naman sila nakita. bago palit ang plugs pero yong air filter di pa pinalitan.
help naman po
- Jun 2005
- 3,774
May 30th, 2016 07:41 PM #2Ilan sakay mo nung una at nung huli na byahe? Malaking bagay ang dami/bigat sa acceleration.
Pwede mo palitan air filter mo kung yun lang di napalitan
- Mar 2014
- 901
May 31st, 2016 12:01 AM #3Nag PMS ang unit mo, pero di pinalitan ang Air Filter. Try running your vehicle temporarily without that old Air Filter. And observe, if it improves your accelaration and speed. Kung hindi, install it back the filter. Nagpalit kamo ikaw ng new set ng spark plug. Nag set ba sila ng timing? Kung hindi, ipa-timing mo. Naka tono kasi ang timing sa dati mo sparkplug, malamang hindi pa sa bago sparkplug. Just my opinion.
Sent from my UP+ using Tapatalk
- Mar 2014
- 901
May 31st, 2016 12:05 AM #4
May 31st, 2016 02:55 PM #5
MT ba ito sir? if it is, pakiramdaman mo, pwedeng nagsisimula ng dumudulas ang clutch.
if AT, paflush mo ATF, then fill in fresh batch.
distributor-less engines doesn't need to be manually adjusted, wala ka ng gagalawing distrubutor for the timing.
the ecu will automatically adjust by itself.
the least TS can do is, reset the ecu.
May 31st, 2016 05:01 PM #6
- Oct 2009
- 2,271
May 31st, 2016 05:13 PM #7
May 31st, 2016 05:48 PM #8
Almost 10yrs hehehe nice. Napalitan na ang fuel filter?
When its a power issue it is normally air or fuel or the ignition.
Another possibility is the throttle body. It probably needs cleaning. 350 pesos in some shops. Pwede rin pa check ang ecu also.
May 31st, 2016 06:00 PM #9
City driving most of the time?
Carbon build-up lang. Italian tune-up kailangan.
Drive it like you stole it.
May 31st, 2016 06:38 PM #10
Good thing you don't have an oil pressure gauge. It'll make you think twice about going 50.
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
