Results 1 to 10 of 11
- Aug 2006
- 98
March 23rd, 2007 11:43 AM #1Mga bro need help
Ano ba sakit ng sasakyan pag madalas pumalya ang makina?
Pina-overhaul ko na ang carburador
Na-top overhaul na rin ang engine nung january pero palyado na uli ngayon
Kelangan bang platinum sparkplugs na ang gamitin ko,hinde yung pangkaraniwan lang?
Yung sparkplug malakas at mabilis mag-karbon.
Carbon Fouling
Ano ba ibig sabihin nito:
1) Over-rich fuel mixture - (mali ba ang gaso na kinakarga ko?)
2) Carburettor mixture settings
3) Float level
4) Choke operation
My mga nag-suggest sakin na ipalinis ko muna ang Gas Tank, Fuel Pump Filter & Air Filter baka daw madumi na at baka sakaling yun ang cause ng pagpalya ng makina dahil sumasama ang mga kalawang o dumi sa pag-akyat ng gasolina.
Bka may iba pa kayong suggestions kung paano maiiwasan ang pagpalya ng makina, paki-post naman po.
Your immediate response would be very much appreciated.
Pwede nyo rin ako iemail sa mga replies nyo -- po1.migs*zipido.com
Thanks
March 23rd, 2007 04:47 PM #2
most probably yung problem ng oto mo is yung rich fuel mixture wherein hindi pantay ang pasok ng hangin (from the intakes) resulting in incomplete burning of fuel. incomplete burning of fuel results in pag-kakarbon ng sparkplug mo. i am sure, pati muffler and exhaust system mo madumi na din. it has got nothing to do with the fuel.
yung pagpapalya, may ibang factors pa like electrical problems (tension wires, etc.)
March 23rd, 2007 05:05 PM #3
in addition to h_g, tamang tune up i.e. correct valve clearance setting,
even non platinum spark plugs will do, contact point kung meron man
yan.
- Aug 2006
- 98
March 23rd, 2007 07:04 PM #4
Happy_Gilmore, ano ba maisa-suggest mo para pumantay ang pasok ng hangin, may kinalaman ba ang karburador jan kahit na-overhaul na rin ang carburador last feb lang?
Possible bang dahil madumi na itong Gas Tank, Fuel Pump Filter & Air Filter kaya rin nagkakaganun?
Salamat pare
- Aug 2006
- 98
March 24th, 2007 07:27 PM #6
magaling na mekaniko ang kailangan mo. yong magaling sa troubleshooting. if possible, stick to 1 or 2 mechanics. para alam nila ang history ng car mo.
- Aug 2012
- 6
August 21st, 2012 03:48 PM #7sir pahelp din palyado din engine ko.. sa unang start ng engine ko pag binobomba ko ung gas ok naman indi palyado.. pero pag naginit na ang makina palyado kapag binobomba ko ung gas ,, nilinis ko na sparkplug at high tension wires ganun padin help naman sir..
- Aug 2012
- 6
August 21st, 2012 04:03 PM #8sir help naman mitsu ko 89 model carb .. kc palyado .. sa unang start ok naman pag binobomba ko ung gas pedal pero kapag nag init na engine aun parang humahagok na sinisinok .. nalinis ko na high tension wire pati sparkplug.. anu po ba dapat kong gawin
August 21st, 2012 06:07 PM #9
- Aug 2012
- 6
August 21st, 2012 09:17 PM #10
Ikaw pala si Daniel.
2023 Toyota Wigo
