Results 1 to 10 of 10
- Feb 2009
- 102
November 2nd, 2016 11:37 AM #1Hi Mga Sir.
Car is Rav 4 2001 4X4 M/T.
Parang wala sa timing, pag tinapakan yung gas pedal pa kadyot kadyot ang andar. bagong palit ang fuel filter bagong linis din ang buong throttle body.
Pinalitan din namin mga spark-plugs at mga ignition coil, air filter.
Pag naka neutral at tinapakan ang gas pedal ok naman ang andar walang palya or delay. pero pag may load na usually 1st and 2nd gear pa kadyot kadyot na ang andar.
Ano kaya posible na pwede ko pa pa check. bagong palit din clutch.
Thank you mga Sir.
- Apr 2008
- 6,237
November 2nd, 2016 12:05 PM #2If at low rpm only, try to check the engine and transmission supports.
Sent from my SM-G900I using Tapatalk
- Jun 2008
- 1,741
- Oct 2009
- 2,271
- Dec 2016
- 39
December 8th, 2016 05:39 PM #6sa EFI system yan sir , same problem with my dad's car, pa check nio po sa specialist para sigurado.. ung trusted nio
- Jun 2005
- 8
December 27th, 2016 07:48 PM #7Kindly advise if resolvd already. I have the same issue wih my Vios. Thanks
- Jun 2005
- 8
January 4th, 2017 03:07 AM #8
- May 2015
- 9
March 22nd, 2017 03:56 PM #10this happens to me pero naiisip ko lang parati na it's because mali ang timpla ko ng clutch at gas...
high idle RPM at engine start
