Originally Posted by
miked
If I may butt in gentlemen,
Problem:
1. white smoke, but not much : is it steady or during cranking only? Puff of white smoke during cranking when cold (be it gas or diesel) means unburned fuel vapor. This could be due to defective glow plugs or the worst, low compression due to worn valves or piston rings.
Steady white smoke means coolant leaking into combustin chamber/cylinder. it could be due to a head gasket failure or cracked head or block.Another culprit could be water contamination
Can this also be the reason why I seemingly lost water in my radiator without a leak in my radiator. I always refill my water reservoir after a long drive. I had it cleaned (radiator) but the loss persist. The white smoke is steady.
2. noticeable oil consumption: by how much in liters, say liters/week or liters/km? afaik, 1 liter consumption in between recommended oil changes is normal. I cant say how much per km since I seldom use the car. Maybe 2-3 per change oil.
3. oil leaking from cylinder head cover and from breather: is it the valve cover or the head gasket? usually, the valve cover gasket gets fried due to the head operates at higher temps. with respect to the breather, is it dripping or weeping oil when the engine is running?
Valve cover. For the breather, it is weeping - crawling maybe.
however, I have no problem with cold start or starting at any time. One click lang siya. it's a healthy one (i guess)
How can I solved the oil leak, white smoke and blowby? To confirm if a complete rebuild/overhaul is required, try doing the ff:
1. Compression test (lowest reading should be 75% of the highest readin) to confirm if it is a head gasket, valve or rings.
2. Oil pressure test: a mechanical gage is plugged into the engine. (as a general rule, there should be 10 psi pressure increase for every 1000 rpm engine speed). The value at idle is usually in the range 7-10 psi. If it is way down south, could be due to excessive bearing clearances.
You may avail the so-called "dukot" repair but it is not recommended because a complete and thorough inspection and cleaning of the engine internals will provide you trouble-free thousand of miles.
My ride is the nissan diesel power pick-up.
Thanks. Really.
