Results 1 to 10 of 16
Threaded View
- Apr 2009
- 429
October 25th, 2015 10:55 PM #7if cylinders #2-4 are still within the std bore, I would just re-sleeve cylinder #1 and bore it to std specs. If the OEM sleeve is thick, then probably reboring it to a slightly bigger size is the next best thing to do. but if the OEM sleeve is thin, then i would not advice reboring to bigger size as internal combustion heat can crack the thinned out sleeve overtime
Probably looks like a Coke sakto. Yes, where did you buy it?
Fire Extinguisher for Car: what brand and type...
