4 na mechanic gumalaw nung makina mo? nako. sana naman naibalik mga bolts sa original nuts niya.
proper engine tear down dapat naka ayos lahat ng part sa table and properly marked, then return all bolts kung saan siya tinagal.
UP ko lang yung thread na to...
Been reading about oil sludge and based sa mga nabasa ko..if ever may oil sludge na visible when you remove the oil cap, kelangan na i top overhaul and remove the oil pan para linisan.
question ko lang hindi ba kaya iflush muna or treat it with hi detergent oil such as delo gold?
The reason is we have a toyota echo car (2nzfe) na nagkakastart na magka oil sludge but quietly and running smoothly, just curious kase it might cause a bigger problems soon.
Thanks.
me too, the distance travel from home to office is 7 kms . I understand low engine operating temp is prone to oil sludge. Given the above situation how often do I REALLY need to change the oil using FC oil ? BTW my total distance traveled in 6 months is only 6k to 8k. (kulang ata sa lakwatsa).
You can doing a full flush first; high detergent oil + Baldwin filter with a close change oil interval. (1,500 kms then 5,000kms). You can also try using an engine flush oil when you do the change oil inbetween.
You can also opt to open up the valve cover and have it cleaned physically then install a new gasket, then use a high detergency oil and good filter. That's what i would do.
You change oil every 5K naman? That should be okay of so. Just don't use full synth and extend to 10k as that's where most of the sludge issues i heard about came from.
[QUOTE=vinj;2701136]You can doing a full flush first; high detergent oil + Baldwin filter with a close change oil interval. (1,500 kms then 5,000kms). You can also try using an engine flush oil when you do the change oil inbetween.
Sir Vinj any recommended na high detergent oil? if i have the valve cover remove, kelangan din ba ibaba pa yung oil pan? thanks sa reply sir really appreciate it.
when you are losing lube oil that fast, the first thing you will have to check is the PCV system. these are routine maintenance procedures that are often missed and people tend to prescribe overhaul even if it was neglect or derelict maintenance. do the routine procedures first. most shops are hungry for cash even how minor the symptom is, they prescribe the most revenue producing jobs taking advantage of people's ignorance
Hi sir,
Any recommended mechanic or shop na expert sa pag dismantle ng ZZ engine? I'm planning to have my altis 1.8G, na pa overhaul due to oil sludge:
If you are near fairview, look for Ryan Marcelo's dadudz autofix. He is the moderator of toyota vios maintenance in FB
Lots of vios owners have their cars serviced and overhauled there and seems he knows his stuff in toyota engines.
Granted yours is an altis, i doubt there are glaring differences in how it is overhauled.
krudo lang gina gamit kong flushing oil. twice a year ko ginagawa. wala talagang sludge ang sasakyan. di ako naniwala na lulutong ang seals dahil lang sa krudo. halos lahat ng trucking at taxi companies, yan ang ginagawa.
Sent from my SM-G610Y using Tapatalk
Hi Sirkosero,
Thanks for your input, I will look for it on FB.. I'm trying to post the picture of my engine so that you can see how bad it looks like, but I cannot post the picture..
Thanks
