Results 11 to 18 of 18
April 28th, 2008 12:27 PM #11
heat it or use ball pin hammer, it should loosen up a bit. Even rusted or stucked up bolts in my experience can be loosen.
if the bolt is somewhat rounded already, you can just weld another nut on top. Wondering why they have to cut and weld oil pan not unless the oil pan thread is worn out.
April 28th, 2008 12:36 PM #12
You can also have your machinist make you graphite or copper washers, your machinist would have so much material just lying around, as for me I just turn those bolts handtight. That is how my grandpa, and dad does it.
April 28th, 2008 12:55 PM #13
First you should get your self an extra for emergencies as these bolts get
stolen. Then using these extra drain plug you can shop around for washers that will fit or you can fabricate yourself from copper sheets. Others uses bicycle tire interiors for these, I prefer copper.
Check out your neighborhood scrap dealers for materials or just look around
your house.
I may look weird but I tell you these drain plugs get stolen.
Always have an extra.
April 28th, 2008 09:57 PM #14
thanks po ng marami....tama nga talga na dapat ay may reserve...dati kasi napudpod na yun tread ng nut ko tpos buy me sa honda...bibili ulit ako para may reserve
April 29th, 2008 01:44 AM #15
marami kasing shop na nagha-hire sa mga walang knowledge sa basic mechanic dahil tipid sa sueldo. Konting training lang sa pagtanggal ng drain plug at paglagay ng oil ay puede na. Your are right, you must aware kung sino ang mga gumagalaw sa sasakyan mo.
Tsikot Member Rank 5
- Nov 2003
- 3,849
April 29th, 2008 07:07 AM #16actually, the problem there is the mechanic. if makita nya na may tama na yung plug, washer or thread of the oil pan he should inform you asap para wala na iba madamay.
- Nov 2003
- 3,849
May 22nd, 2008 08:49 AM #18what does use of a lifter have to do with putting the bolt on correctly?
Just ordered backup charger. Will keep you updated...
