Results 1 to 9 of 9
    Sep 2006
    guys confirm ko lang lagi ba dapat naka max ang engine oil level sa dipstick?
    Jul 2006
    Not really.
    Anywhere between the high and low mark when the engine is at operating temp should be fine. If engine is cold, basta nearer to the high mark because when the engine gets hot, the oil level goes down (due to the oil circulating throughout the engine).
    dagdag ko lang, try to maintain it sa high para kung sakaling nagbabawas man ng oil ang engine mo marami pa itong sapre or reserve bago mag low or maubos ang oil mo.
    and pag nasa high ito compare sa low ang ratio ng contaminants sa oil masmababa.
    Nov 2003
    anywhere between the high and low level. pero top up so umabot sa high.
    Sep 2006
    so ok lang po kung without the engine running 75-80% ung level sa dipstick?
    Jul 2006
    As long as it has warmed up properly, yes. If it's a dead cold engine, starting the engine will leave less oil in the sump, and once this engine has shut off when warmed up, it will not read that level - maybe closer to L.
    Aug 2005
    Quote Originally Posted by MasterZerg View Post
    As long as di nababawasan, OK lang.
    Nov 2003
    always check 1st thing in the morning.
normal level ng engine oil sa dipstick
