Results 1 to 10 of 12
- Oct 2009
- 6
October 5th, 2009 12:17 AM #1Hi Guys,
My beloved Nissan Exalta SLA 2000 Model got submerged sa baha (lagpas bubong) in our basement parking after bagyong ondoy. Pinasok ko na siya sa Auto Shop. Ginawa na lahat ng necessary cleaning and draining ng mga fluids for a submerged car. Nagstart na siya kaso palyado pa ang makina. Pinacheck na din namin ang computer box and everything is normal. Malakas ang electricity and fuel injection is okay. Pinalitan na din ignition coil, maganda na flow ng electricity sa spark plugs (new spark plugs din). Wala ng problema sa starting ng engine (single click na), PERO once you put/press the gas or i-gas siya, palyado ang makina. Para siyang nagchochoke or nahihirapan. Ano kaya ang pwedeng maging problem ng engine? Need help mga Pare. Nag-aalala talaga ako sa auto ko. Wala na kaming maisip na solution.
Maraming salamat! Please I need you help.
October 5th, 2009 12:45 AM #3
Are you sure the engine ECU is fine? It might be running on "limp" mode. It would explain the lack of power.
Or the air flow sensor is busted/defective. Assuming the engine can idle using default settings but cannot run at higher revs due to improper signals from the air flow sensor.
- Oct 2009
- 6
October 5th, 2009 05:26 PM #4
October 5th, 2009 05:29 PM #5
You can have it brought to Speedlab and let them use their diagnostic computer check your car's ECU for error codes, etc.
Website and contact info: http://www.speedlab.com.ph/
- Oct 2009
- 6
October 5th, 2009 05:30 PM #6
We tried to replace the airflow system with a surplus one. But still, same thing happened. We are trying to find another replacement airflow sensor again, it might be the surplus one is also busted. About the "limp" mode thing, how will you find out if it's in the said mode? do you have any other advice for the cause of the problem?
Thank you so much for your help.
- Oct 2009
- 6
October 5th, 2009 05:51 PM #7
I assume ECU and computer box are the same. We already had it checked and scanned. Everything is normal according to the readings. Hopefully, the airflow system sensor is the problem. We have no other ideas for the cause of the engine problem.
Thank you again for the help.
- Jan 2008
- 380
October 6th, 2009 09:02 AM #8Parang naka-limp mode nga yung takbo, pero pag limp mode the check engine
light sa dash board ay nakailaw.
Wala ka bang detailed check-list ng mga ginawa sa auto shop.
Nagalaw ba yung timing during the process, some mechanics are too lazy to remove all the timing cover for proper timing belt reinstallation.
Sa casa mo ba pinagawa, ano yung capability ng OBD nila.
Di naman ba palyado yung idle, pag-on ng aircon do the spark advance mechanism work.
Kung malapit yung Spedlab sa inyo di kaya mas ok na kumuha ka ng 2nd opinion.
- Jul 2009
- 99
October 6th, 2009 04:33 PM #9you may also want to include the throttle position sensor, the maf sensor, crank and cam position sensor, also the advance mechanism of your ignition system.plus the connectors of your wiring harness.
- Oct 2009
- 6
October 6th, 2009 04:43 PM #10
Thank you sa response Sir.
Hindi umilaw ang check engine light. So most probably hindi siya nakalimp mode.
About the detailed check list, all process na for submerged car repairs nagawa na. ok na ang start ng engine. The problem is when magrerev ka, para siyang nachochoke. We are definitely hoping na sa airflow system ang problem. Busted/defective sensor. Naghahanap pa kami ngayon ng replacement (surplus/2nd hand). Do you know how much aabutin to? Sana nga ito na ang solution sa problem ng kotse.
Nagalaw yung timing process. Pero sabi ng mechanic ko, inayos naman na niya ng mabuti ang timing kasi nagstatart agad yung kotse. Walang kahiraphirap istart.
Sa Garaje Auto shop ko siya pinagawa along Vito Cruz Extension sa makati. ano po ba yung OBD? pinascanner na namin yung computer box tsaka dinala na namin sa RAMSA sa evangelista, ok naman normal daw.
Pag Idle naman sir, ok lang yung makina. Hindi siya palyado. Pagnagrerev ng todo ok siya pero parang nagchochoke before magnormalize... ok din pag-on ng aircon.
Iniisip ko na nga magpa-2nd opinion na. kasi naaawa nako sa kotse. gusto ko na siyang gamitin at alagaan ulit.
Maraming salamat sa tulong Sir.
i wonder, are the usual published suspension adjustment specifications supposed to be adjusted...
Wheel Alignment
