Results 1 to 10 of 18
- Feb 2014
- 112
March 29th, 2014 05:30 PM #1mga bossing, normal po ba na manginig ang makina pag bukas ang aircon.. 800 rpm po.
- Jan 2014
- 18
March 29th, 2014 07:12 PM #2normal yan sir. mga 200rpm more or less ang increase pero sandali lng yun seconds lng. balik normal idle rpm. kaya wag isabay yun on ng aircon at andar ng sasakyan. kung malakas talaga yung nginig pa check mo na lng yun sa trusted mechanics natin.
March 29th, 2014 09:12 PM #3
di dapat manginig yan. i compensate ng aircon actuator/selenoid valve ang hatak ng aircon compressor. paki check mo ang actuator kung ok pa ba. hope this helps.
- 52,972
March 29th, 2014 10:01 PM #4
- Oct 2009
- 2,271
- Feb 2014
- 112
March 31st, 2014 08:20 PM #6
- Feb 2014
- 112
April 2nd, 2014 08:17 PM #7mga bossing, 800 rpm a/c off, tapos pag bukas ng aircon biglang tataas ng hanggang 1.1k rpm pero babalik din ng 800 rpm.. idle up po nga kaya ang sira? may inaadjust po ba dito o palit na ng pyesa?
April 2nd, 2014 08:26 PM #8
kung ganyan, okay ang idle up mo.
my take, i check mo yung belt mo baka sobrang higpit and/or kung umiingay and the worst baka may isa up to 2 kang engine support na sablay na.
teka teka ikaaw din ba yung naka civic na eg? ph12 na makina? try to check muna yung tune up. patignan mo using timing light parang 250 petot lang iyun. tapos check kung malinis yung carb, air filter, spark plugs et al. diyan ka muna sa mura murang gawaan.
pero my take, engine support na iyan na naapektuhan na lang ng mga bagay na nasa itaas. and of course sa kalumaan na din.Last edited by brainmafia_310; April 2nd, 2014 at 08:29 PM.
- Feb 2014
- 112
April 2nd, 2014 08:55 PM #9
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
