Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Feb 2012
    mga paps may naka subok naba sa inyo to
    Ah ok! In MBCP we use LiquiMoly Diesel Purge. Proven effective in cleaning clogged injectors. But if the car still smokes like a fogging machine, then something is wrong (subjective issue).
    Even abroad. Diesel purge din sikat sa chedeng. You purge direct to the injection pump or pour it lang sa gas tank?
    Jul 2006
    I buy 2 bottles of diesel purge, one bottle I feed to the engine directly, then ikot-ikot sa subdivision. The second bottle I pour into the tank. Then, italian tune-up sa highway .. :D
    wow. so you purge directly to the injection pump then you drive around? yung mga nakikita ko usually idle lang.
    Jul 2006
    Yup, pwede naman eh, just make sure to tie things down para hindi matapon or mahulog. I don't usually go far, just around the block at baka maubusan ako ng purge, mahirap din mag-bleed ...
    You can let it idle though, but it takes awhile for the engine to consume one bottle. :D
    Parang mas may sense ganyang siste ng pag-purge ah. Para malinis nga husto pati exhaust.
    nice! i'll try this also next time. btw, which one first, direct to engine or fuel tank?
    Jul 2006
    This is what I do actually;
    Diesel Purge Mercedes diesel maintenance tips
    then I just add the second bottle after everything is buttoned up. :D
    Feb 2012
    Dec 2007
    Why are they adding it to the intake like that? You can bet it's just 2T oil.
NEWOIL TREATMENT  para sa black smoke
