Results 1 to 11 of 11
    Feb 2006
    hi po,
    just recently changed my timing belt , napansin ko po medyo gumanda yung idling and much smoother po yung tunog ng engine ko.
    i noticed lang po that ngayon during starting po is medyo di na one click yun starting ko,as in medyo hirap po sya magstart .ideally po ba the timing of the engine is checked after the replacement of the T belt?
    salamat po mga sir
    May 2007
    You must set your timing by using timing light to ensure your car BTDC this allows the fuel mixture to have a more comlete burn ensuring full power to the compression stroke. You have to know your engine timing, different car have different timing and no idea what kind of vehicle you drive.
    Quote Originally Posted by threx666 View Post
    hi po,
    salamat po mga sir
    after a TB replacement, timing should be checked and adjusted.
    Kumusta naman ang power hindi ba nagbago?
    Jan 2008
    Kung diesel yan, baka may palya yung glow plugs.
    Nov 2007
    sama ko na din dito sa thREAD ok lang ba sa L3 na hindi na paganahin ang timing belt i mean e yung sa langis ba yun o maliit na timing belt?
    Feb 2006
    power ?hmmmm medyo smooth lang sir.not sure sa power
    and also my ride is Galant 7G po pala .
    i also noticed that during idling po pala something like parang nabubulunan or parang sinisinok yung idle nya.
    thank you po sa mga inputs.
    Oct 2008
    sir valve timing po yan. paki check na lang po.. tnx
    Quote Originally Posted by technismo View Post
    This is right. Definitely.
  10. #10
    Baka lumampas ng ipin yung camshaft pulley nung binalik yung timing belt. Have a mitsu expert correct your camshaft position/valve timing. Kung swak naman yung timing marks eh no need to adjust your ignition timing.
    Nov 2003
    actually there should be no difference in how the engine runs when you replace the timing belt. if it got smoother it was because mali sya dati and tama na sya now, or some other reason.
    also, ignition timing will not move. if you see the mechanic move the distributor to compensate for wrong timing that means the belt is off by a tooth.
Newly Changed TBelt ,starting issues?
