Originally Posted by kinyo dapat ... rpm without AC = 800 - 850 rpm with AC = 850-900 adjust the rpm without AC first with idling screw, then adjust idle-up screw with AC on ... magkaiba yung idling scew at idle-up screw follow up... help please kung dati mas tumataas ang idle kapag nag-on ako ng AC, pero ngayon bumaliktad na. pag hindi naka-AC nasa 1000 rpm ko pag naka-AC bumababa sa 500 is this normal? TIA
try to check yung fuel pump mo.
Specs, prices, features: Everything you need to know about the all-new Hyundai Kona | TopGear PH...
Interesting thread—really important to consider the broader impact of the National ID Law beyond...
Looks like its is due for release next year: https://www.youtube.com/watch?v=1mLrd78Deng Also...
Yes, the countdown timer was a welcome feature. It took out the guess work when crossing an...
Well don't get mad at me... I have nothing to do with it. I, too, prefer the timer. Then again,...
the flashing green light comes only during the last five seconds. the countdown timer shows the...
Not fully sealed. The coolant pressure cap keeps the pressure inside the system at a set...
Enter your email address:
Delivered by FeedBurner
Hyundai Kona (2nd Gen)
