Results 1 to 10 of 11
October 24th, 2012 01:00 PM #1
Good am bros.. Sensya na, tanong agad bungad ko.. Anyway.. ito yung ginawa namin ng mechanic sa amin..
1) Turn off your engine
2) Locate your diagnostic connector, and look for terminal "OX1" and "E1"
3) Get an analog multi meter (any brand can do)
4) Select to 2.5Vdc range
5) Insert the red colour probe to "OX1", and black colour probe to "E1"
6) Place the multi meter on the windscreen, as near to the driver side as possible
7) Start your engine
8) Wait till it reach working temprature
9) Keep your RPM at 2500
10) Observe you multi meter's needle. It should be moving up and down, from 0 to 2/5 of full scale.
11) Time your watch, a good O2 sensor will move the needle up and down for at least 8 times in 10 sec.
ang prob, di nagmove ang needle - idle at any scale.. kaya ngayon, magpapalit na ako ng sensor.. Just would like to ask kung ano yung part number para sa oxygen sensor (bank 1) ng vios 2006 1.5g.. again.. I apologize for the disturbance..
TIA..
- Jan 2008
- 4,726
October 24th, 2012 01:04 PM #2may problema ba sa acceleration?? alam ko kahit disconnect mo yang o2 sensor bank 1 aandar pa din ang makina mo.. iilaw lang yung check engine mo pag umaandar ka na.. may portion sa pag accelerate mo na iilaw yung check engine light indicating na sira or disconnected yung o2 sensor bank 1
October 24th, 2012 03:24 PM #4
* yapoy - yup.. ok naman accelaration.. di lang talaga nawawala yung ilaw ng check engine..
* jick - vios 2006 1.5g sir..
- Jan 2008
- 4,726
- Jan 2008
- 4,726
October 24th, 2012 04:18 PM #7so lumabas sa scan na O2 sensor bank 1 ang faulty?? try mo disconnect yung O2 sensor, then start mo check mo kung mawala yung cel
- Jun 2009
- 325
October 25th, 2012 10:06 AM #8Suggest avoid using analog multimeter such as Sanwa brand when performing electronic diagnostics. It has a higher current output which might damage other components. Better use digital multimeter in diagnosing sensor problems and has more accurate readings compared with the Jurassic analog type.
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
