Results 11 to 13 of 13
THE AUTO SPECIALIST
- Mar 2006
- 607
June 28th, 2009 12:47 AM #12
Bought an ignition coil yesterday, and had it installed today. Mukhang yun nga daw ang problema, sabi ng mekaniko. Pag umiinit yun ng sobra, walang power daw na sinsu-supply sa fuel injectors, kaya the engine stalls.
Drat, it was what I suspected all along, lipad tuloy yung 2.4k ko for the surplus main relay and labor. Now I have 2 fully functional main relays. Tapos, mali pa yung nauna kong pinabinili na ignition coil sa Banawe (di kasi dala ng tao ko yung sample). So soli ko na lang Lunes, sana puwede i-refund.
Sana naman ok na talaga. Already spent over 8k fixing this problem.
June 28th, 2009 11:29 AM #13
don't just throw parts on it, shotgun repair is expensive. why not check what's causing the MIL to illuminate? depending on the year model of your car there are lots of generic code scanner (reader) around that can read the codes im sure it's the best way to start the diagnosis. you can also retreive the code manually (search the internet)
Xiaomi E-Car
