Results 1 to 10 of 28
- Jul 2005
- 61
September 30th, 2005 10:02 AM #1hi. needed help fast!
i was driving on my way to the office. ok, ganda ng takbo ng car. then i have to stop over to a gas station to refuel. there i have to turn the engine off. upon starting again, i noticed that my idling is dropping until i reached the parking lot. so, turned the engine off and was about to leave. curiousity, i tried re-starting the car again and it started naman but namamatay agad.
how can i resolve this problem? what would be the cause?
thanks.
September 30th, 2005 10:07 AM #2
try to smell the exhaust... if there's too much gasoline - the af mixture is off.
- Jul 2005
- 61
September 30th, 2005 10:21 AM #4i will try that. pero pag-start ko pa lang, hindi man tumatagal ng mga 1 sec patay agad eh.
how can i get the car running until i reach the nearest mechanic shop?
- Jul 2005
- 61
September 30th, 2005 10:27 AM #6galant 95 SS.
a friend is speculating that it might me the alternator.........is it?
September 30th, 2005 10:47 AM #7
nope, not alternator. you said you can still start it (which means the battery is not dead), so kahit sira na alternator mo dapat umandar pa din kasi may charge ang battery. if this happened suddenly (you said ok ang takbo before you gassed up) then i suspect water in the tank, the gas station had water in its tanks and they pumped it to your car.
- Jul 2005
- 61
September 30th, 2005 10:51 AM #8talaga?
ang sama naman nila.........mahal na nga ginagastos natin for the gasoline of our cars tapos nandadaya pa sila.
what can i do to make this running again?
but toyota outfits their cars with locally manufactured yokohamas. i just follow suit. after many...
Finding the Best Tire for You
