Results 1 to 15 of 15
    Guys,
    Left the other car for a 3 day vacation, last time I used it was for a 10 minute warm-up. I got back, it won't start.
    iam3739.com
    Jan 2008
    if its crancking? check the fuel pump and fuel filter.. gasoline engine?
    battery drained?
    Oct 2003
    nalunod saan? bumabaha ba sa inyo?
    battery drained?
    x2 most likely
    Sep 2008
    why the title po? napatignan mo na ba cia sa mekaniko? ito ba findings nia?
    Oct 2008
    nalunod b ng gas? tangalin po yung airfilter para para magkaroon ng air and fuel ratio tnx
    Sep 2008
    ayaw mag start,walang ridondo ba ibig mong sabihin? pag hindi nagriridondo ang engine,battery yan. nadiskarga siguro ang battery mo.
    Sep 2005
    jump start lang yan kung na-drained yung battery. tapos kakarga na yan once mag-start na.
    Guys salamat sa reply.
    nagtatampo siguro tong isang kotse kasi madalas ko ginagamit yung matipid.
    nalunod daw sya ng gas. Check ko gawin yung mga snabi ninyo, okay pa naman batteries.
    iam3739.com
    paano malulunod if you don;t step on the gas pedal? iniwan mo nga diba? unless you kept on stepping on the gas nun hinde ayaw na mag start
    ako rin...pwede lunod kung cranking naman, the other way around - bakit ayaw mag crank?
Nalunod daw?!
