Results 11 to 17 of 17
June 10th, 2009 10:45 AM #13
wala po ako nakikitang leak rad cap kapalit ko lang last 3 months btw pag nauubos sya sa traffic at idle lang ang engine with aircon on pero di nauubos kahit gaano kalayo ang long drive
June 10th, 2009 12:36 PM #14
- May 2009
- 14
June 10th, 2009 01:23 PM #15
June 10th, 2009 03:22 PM #16
sq rekta na kasi ang clutch fan nito,, sbi ng friend of mine ko palit daw ulit ako ng rad cap para sure minsan kasi daw pentong ang rad cap kahit brand new,, btw sir masama ba or ayus lang ba medyo maluwag ang reservior cap ng van ko?
June 11th, 2009 04:20 AM #17
First off check the radiator cap on it (you said new....maybe wrong pressure cap), when they go bad it causes one to loose pressure,and with the pressure loss you also loose coolant, also check the reservoir jug, make sure its not busted, and you might want to have a pressure check done on the car, this will tell if it has a bad head gasket, it will show also if there's a leak in the system, that's the fastest way to find out where its going to. Good luck on it.
Xiaomi E-Car
