Results 1 to 8 of 8
July 19th, 2012 09:09 PM #1
My ride:
Kia Besta 1998 - 2.2L diesel engine
Mileage - 117km
My problem: I notice a bit more smoke when the fuel level drops to 1/4 tank capacity. My fuel is Shell V-power Nitro Diesel.
My question - What kind of problem do you suspect I might have and what should I have checked?
Regards - Dlv
- Apr 2010
- 742
July 20th, 2012 09:31 AM #3
When was the last time you changed oil, oil filter, fuel filter, and air filter?
Also,use of vpower and turbo diesel is almost a waste of money for old school diesel engine. Use "cleaner" diesel nalang like seaoil or unioil coupled with 2t
July 20th, 2012 09:45 AM #4
fuel tank nyo sir baka po madumi na.... nakakasip ng dirty fuel kaya pag 1/4 tank nalang dirty fuel na ang nasusunog.... check nyo po fuel filter.... or replace it with a new one, then after 2 weeks or 350kms. inspect it again kung madumi na agad kahit kunti or dark na color agad ng fuel, it means its time to pull down your fuel tank for cleaning....
July 23rd, 2012 12:34 AM #5
hmm parang i notice this problem also.. pag malapit na mag empty yung diesel ko.
1994 pickup gamit ko, try ko rin mag palinis ng fuel tank
July 23rd, 2012 02:45 AM #6
^usually, dirt, contaminants and foreign substances in diesel fuel or any other fuel settles at the bottom of its container, in this case the fuel tank. Make sure to AVOID having less than a quarter of fuel in the tank for this will have many implications on your engine,.
July 30th, 2012 08:47 PM #7
July 30th, 2012 08:50 PM #8
Thanks, will try seaoil or unioil. I really had the idea that the more expensive fuels of petron and shell will smoke less ...
Yes, i do think so. Since it's based on the 4th-gen delica/space gear, which in turn shares some of...
Mitsubishi Philippines
