Page 1 of 7 12345 ... LastLast
Results 1 to 20 of 136
    Jan 2003
    Other than having a turbo and intercooler kit. What other mods would you do to your ride to increase/maximize performance and interior/exterior looks? : )
    basic i/h/e intake headers exhaust.
    intake open type filters..
    pls check the older threads...thanks.
    Turbo Boost Controller. :D
    Jan 2003
    thanks GlennSter. : ) i'll do just that.
    roydok,
    magkakano ba ang turbo boost controller dito sa Pinas? Big help ba talaga ito sa mga may turbo? : ) thanks!
    4-5 thousand ang turbo boost...
    Without any of those turbo upgrade....I would suggest a free-flowing air-filter like k&n.... a CAI set-up or a snorkel set-up para mas malakas at mas malamig hangin sa engine.
    kung may turbo ka.........
    8 washers lang yan
    kimpoy
    wat do u mean 8 washers?sounds interestng...
    Cranking up the boost on the 4D56 Turbo Intercooler
    here's the link, complete with step by step procedure and pics
    Just be careful not to overdo the boost. If you have a turbo engine... changing to a free-flow intake and bigger diameter exhaust piping will help.
    What's your ride bTW?
    bos kips,kita ko na ung "how 2 install washers & boost ur turbo diesel 4 dummies" :mrgreen: pede ba yun 4 kia carnival?tnx
    On diesel-fed engines, you can have the cylinder head machined. Intake/exhaust port and polished, stress relieved, over-sized pistons, flywheel skimmed to match you clutch disc. Ceramic coating may also help contain the heat inside the combustion chamber since diesel engines use heat to burn its fuel.
    Ungas, kapag pina machine yung cylinder tapos gumamit ng oversized pistons, di ba magincrease ang displacement ng engine? yung 4.2li ng safari baka maging 4.25li ? :roll:
    Signature
    kung cylinder head lang, it will not increase the capacity of the engine. What do you mean by have the head machined? shave it?
    boybi::: Ang tanong kung may parts na available pang-oversize. What I mean is, kung meron man oversized pistons minsan wala naman piston rings. Yes, tataas din ng konti ang displacement.
    ARB::: Dipende sa cylinder head, kung overhead cam ang engine, there is a possibility na tumaas ng bahagya but not easily noticeable. Cam lobes can be adjusted. valve seats machined into three to five angle for smoother intake and exhaust. Dome type combustion ceiling. Maraming pwede gawin. But ofcourse, there is the factor that the machined parts will depend on how sturdy the metal is.
    Jan 2003
    ahehe :roll: dami pa la pwede gawin! :D thanks guys!
    Jan 2003
    sir kimpOy! 8 washers lang ha! :twisted:
    yes sir virtual free!!!
    nakita mo ba yung link?
    marami akong hindi maintindihan...
    Any particular modification i should do for my ride para mas malakas tumakbo, more quiet engine, better fuel efficiency... Sobra na ba ako mangarap? Hehehe
    btw, my ride is xuv at.
    Hmmm... mukhang mahirap yata yang plano. Malakas tumakbo, panigurado malakas din sa konsumo. Kahit na may intercooler turbo pa available para sa makina, dagdag sa konsumo ang extra power na kailangan.
    masarap mangarap! =)
Mods to a diesel engine? : )
