Results 1 to 10 of 16
October 4th, 2013 09:22 PM #1
Just had a UOA on my oil in my truck done recently by Monark. With all the interest and discussion about filters, oil change intervals, quality of synthetic vs mineral etc, I thought it would be good to contribute some hard data. Here are the results:
Vehicle: D40 Navara
Fuel: Shell V-Power Diesel
Engine oil: Mobil 1 Turbo Diesel Truck 5w-40
Km's oil run: 6,000 (mostly stop and go traffic)
OEM oil filter
OEM fuel filter
Wear metals:
Cu 1
Fe 10
Cr 0
Al 2
Pb 0
Contaminants:
Si 9
Na 2
Water, fuel and antifreeze all negative.
Viscosity, Cst * 40degC: 82.6
TBN: 10.3
No data on soot level though. Have to get back to them for that. Wear metals are low, TBN is pretty much like new. Only 5% left on viscosity loss though according to the lab. Si seems to be high compared to UOAs abroad, maybe due to all the dust here. I'm looking to change the filter to a LF3400 and then run it to 10,000 just to see how it goes.
Thoughts?Last edited by Wh1stl3r; October 4th, 2013 at 09:59 PM.
- Nov 2009
- 3,484
October 4th, 2013 11:16 PM #2Good info.
I'm a Mobil1 TDT Baldwin B233 user for 10k-use, keen also on looking at the wear elements. Maybe we could compare notes.
Mind to share where's that Monark located and how much did it cost for the lab?
October 5th, 2013 12:15 AM #3
October 5th, 2013 12:19 AM #4
No prob bro, the more data the merrier.
Monark lab is at:
South Expressway cor. Magsaysay Road, San Pedro, Laguna 4023. Tel. 8696748 loc 2285.
You can bring oil samples at their Q.C. branch near Eastwood and they'll just send it to the lab:
13 Economia St. Bagumbayan, Q.C. Tel. 6350901
There's also a branch in Caloocan but not sure if they accept samples there. Sample size is 250mL. Test costs Php 1,0xx.xx.
October 5th, 2013 12:24 AM #5
I know, right? I called them to ask maybe there was a mistake re: TBN but they confirmed yup, it was 10.3. I think Shell V-power diesel is still Euro 2 (or they'd be marketing the hell out of it if Euro 4) so should be 500ppm. Could their additives have that much effect on conserving TBN?
October 6th, 2013 07:58 PM #6
October 7th, 2013 07:35 PM #7
Copy that, thanks. Afaik it's still 500ppm. That's why I thought the fuel additives (V-power) had something to do with the almost new level of TBN. Still, I agree, pretty impressive TBN.
Called them up today and apparently they need a virgin oil sample as a baseline to get the soot level. Anyway here's the oil's PDS:
Specifications and Approvals
Mobil 1 Turbo Diesel Truck meets or exceeds the requirements of the following industry and builder specifications: 5W-40
API CJ-4, CI-4 PLUS, CI-4, CH-4/ SM, SL, SJ
ACEA E7 Issue 2
Caterpillar ECF-2,ECF-3
Typical Properties
Mobil 1 Turbo Diesel Truck 5W-40
SAE Grade 5W-40
Viscosity, cSt (ASTM D445)
* 40ºC 97.9
* 100ºC 14.5
Viscosity Index 153
Phosporous (ASTM D4951) 0.11
HTHS Viscosity, mPa•s * 150ºC (ASTM D4683) 3.8
Sulfated Ash, wt% (ASTM D874) 0.95
Total Base #, mg KOH/g (ASTM D2896) 10.7
Flash Point, ºC (ASTM D92) 215
Density * 15.6ºC g/ml (ASTM D4052) 0.85
According to Monark the acceptable viscosity change is -/+20%. The PDS puts the used sample at around -15%. Given that there is next to no fuel dilution, why the big drop? Could the claimed viscosity be off compared to the actual?
I'll try to drop off a virgin oil sample next week to complete this UOA. The missing info re: actual virgin oil viscosity and soot level are the only things left that should determine how much longer this oil could be used.
- Mar 2003
- 248
October 17th, 2013 09:25 AM #8Any update sir on this? Been using this for ober a year now in 3 of my toyota d4d engines. Super grandia, fortuner and innova. But i changeoil every 5k.
October 24th, 2013 10:31 PM #9
Sorry I haven't gotten around to doing it yet.. Not time to go to Monark. Will update as soon as able.
How's the performance on the D4d? We use Royal Purple on our D4d, haven't tried this oil on the Toyota yet.
- Apr 2012
- 3,469
With this sort of gadget the thing to keep in mind is "you get what you pay for". I've been in...
Rear view mirror dashcam, help me choose...
