Results 1 to 11 of 11
    Aug 2010
    Guys,
    ano kaya ang tama nitong Toyota Corolla ko, btw, I'm driving a 1996 Toyota Corolla, so here's what happened last time, inilabas ko yung kotse para pakargahan ng gas sa malapit na gasolinahan (kase near empty/ halos running in empty range na yun nung makarating ako sa gas station) I gas up 150 pesos which approximately 2.8 liters..then after that di pa ako nakakalayo, mga meters away pa lang dun sa pinagpagasan ko e, while driving it, it suddenly stalls..then I tried to restart it again pero ayaw na niyang umaandar, malakas mag-reredondo yung makina kaso ayaw talaga tumuloy umandar/mag-turnover--redondo lang ng redondo, I check possible cause of the problem like busted fuse, pero ok naman, buo yung mga fuses, I check spark plugs for dirts pero ok naman yung mga tip niya, sinubukan ko push start/kadyot-tulak pero ayaw..i tried several times of restarting it pero wala talaga, hanggang sa humina na yung battery ko.
    Quote Originally Posted by zap.FREEDOM View Post
    Guys,
    Have your timing belt checked.
    I agree with Falken, check your timing belt.
    Or your fuel filter could have gotten clogged. EFI or carb?
    May 2004
    Pa check mo timing belt mo...
    clogged fuel filter will still let the engine run but limited revs.
    Jul 2010
    Baka diesel nakarga sa kotse mo.
    Quote Originally Posted by Chinoi View Post
    paktay have your timing belt check.
    Aug 2010
    whoooo! kinabahan ako, kala ko putol na timing belt...hindi naman pala, sabi ng pinsan ko, kakarereplace lang daw niya yung timing last May of this year..chineck ko din para makasiguro, bago-bago nga yung timing belt ang di ko lang masiguro e baka tumalon/nag-slip yung timing belt, di ko masyado na-check yung tensioner e kasi sabi ng barkada ko may instances na ganun...o pwede rin daw sa ignition system kaso duda ako kasi nakapagpa-start pa nga ako dun after magpa-gas tapos ano yung bigla na lang mawawalan ng kuryente or papalya yung ignition system
    it is a carb sir vinj, yep..luma na nga yung fuel filter malabo na tignan e, madumi na nga rin..pero bago mangyari yung tirik case e may napansin na akong kakaiba sa Corolla while driving it on past few days...kapag nag-fufull throttle ako/ibibirit (in 1st gear lang) or mag-aaccelerate e may smooth takbo naman kaso yung nga pag medyo pabirit na siya or in full thort's in 1st gear e nagjejerk/kumakadyot na siya kaya nag-shshift na ako into second gear...related din kaya ito? subukan ko i-prime yung karburador baka sa kaling umandar
    Check the carb. That happened with our Sentra before after it was left parked for a long time (coupled with a clogged filter). Had to get it overhauled. The symptom was medyo sinok-sinok yung takbo even if you gas it hard (nalulunod lang) and eventually, it died and wouldnt start. Redondo lang ng redondo... changed the fuel filter and primed the carb (with matching sakal linis) to make it start up again but it still would die down or hesitate at times, until we had the carb overhauled.
    Aug 2010
    Thanks for the advice sir Vinj, try ko po gawin yan pati yung pag-spray ng carb cleaner, pa-overhaul ko na rin po para peace of mind na rin.
TOYOTA COROLLA suddenly STALLED
