Results 1 to 11 of 11
    Aug 2010
    Guys,
    ano kaya ang tama nitong Toyota Corolla ko, btw, I'm driving a 1996 Toyota Corolla, so here's what happened last time, inilabas ko yung kotse para pakargahan ng gas sa malapit na gasolinahan (kase near empty/ halos running in empty range na yun nung makarating ako sa gas station) I gas up 150 pesos which approximately 2.8 liters..then after that di pa ako nakakalayo, mga meters away pa lang dun sa pinagpagasan ko e, while driving it, it suddenly stalls..then I tried to restart it again pero ayaw na niyang umaandar, malakas mag-reredondo yung makina kaso ayaw talaga tumuloy umandar/mag-turnover--redondo lang ng redondo, I check possible cause of the problem like busted fuse, pero ok naman, buo yung mga fuses, I check spark plugs for dirts pero ok naman yung mga tip niya, sinubukan ko push start/kadyot-tulak pero ayaw..i tried several times of restarting it pero wala talaga, hanggang sa humina na yung battery ko.
    Quote Originally Posted by zap.FREEDOM View Post
    Guys,
    Have your timing belt checked.
    I agree with Falken, check your timing belt.
    Or your fuel filter could have gotten clogged. EFI or carb?
    May 2004
    Pa check mo timing belt mo...
    clogged fuel filter will still let the engine run but limited revs.
    Jul 2010
    Baka diesel nakarga sa kotse mo.
TOYOTA COROLLA suddenly STALLED
