Quote Originally Posted by zap.FREEDOM View Post
Guys,
ano kaya ang tama nitong Toyota Corolla ko, btw, I'm driving a 1996 Toyota Corolla, so here's what happened last time, inilabas ko yung kotse para pakargahan ng gas sa malapit na gasolinahan (kase near empty/ halos running in empty range na yun nung makarating ako sa gas station) I gas up 150 pesos which approximately 2.8 liters..then after that di pa ako nakakalayo, mga meters away pa lang dun sa pinagpagasan ko e, while driving it, it suddenly stalls..then I tried to restart it again pero ayaw na niyang umaandar, malakas mag-reredondo yung makina kaso ayaw talaga tumuloy umandar/mag-turnover--redondo lang ng redondo, I check possible cause of the problem like busted fuse, pero ok naman, buo yung mga fuses, I check spark plugs for dirts pero ok naman yung mga tip niya, sinubukan ko push start/kadyot-tulak pero ayaw..i tried several times of restarting it pero wala talaga, hanggang sa humina na yung battery ko.
Have your timing belt checked.
