Results 6,501 to 6,510 of 6585
- Feb 2014
- 2,715
October 24th, 2023 11:57 PM #6501
i didn't say that difference isn't big between group2 and 3, what i said was the difference is probably smaller than what you think it really is. if your manual specifically says use xxx due to special requirements then there's probably a good reason to use xxx
5w30 vs 10w30. that 5w is important in cold countries so oil can flow during cold start. it's always hot here so we don't need 5w at all. advantage of 10w is it needs less viscosity improvers than 5w to reach 30 when hot i.e. it's naturally thicker
October 25th, 2023 09:57 AM #6502
I've started using 15w40 "fleet" oil on my Diesel because they're even cheaper and often available in bulk.
15w has a boundary temp range of -25°C. That's nowhere near what we'll ever experience here.
I just need to change it every 5-6k or one year.
October 25th, 2023 10:32 AM #6503
Heavy duty dino JASO DH1? Good for old diesels...Not ideal for DPF-equipped.
Sent from my SM-S901E using Tsikot Forums mobile app
October 25th, 2023 10:44 AM #6504
- Apr 2012
- 3,469
October 25th, 2023 12:02 PM #6506I use 15w40 Delo 400mgx for my Grand starex with dpf.
Sent from my SM-A528B using Tsikot Forums mobile app
- Jul 2009
- 2,618
October 25th, 2023 12:29 PM #6507
October 25th, 2023 01:18 PM #6508
Not the case here. According to the spec comparison, the amsoil OE 5w30 is thicker at 100 celcius than the repsol 10w30.
By the way, out of curiosity, I currently put in Ravenol DXG which has PAO/Ester base stock, and honestly I really can't tell the difference in performance but strangely enough, the oil doesn't turn black as fast even after months of use.
October 25th, 2023 04:22 PM #6509
If oil isn't turning dark, it may not be picking contaminants up as it should.
- 54,303
October 25th, 2023 08:36 PM #6510
A little ot: I disputed several charges credited to me a month ago and mptc finally corrected ...
cavitex easydrive error
