Page 650 of 659 FirstFirst ... 550600640646647648649650651652653654 ... LastLast
Results 6,491 to 6,500 of 6585
    Jun 2013
    #6491
    Quote Originally Posted by Vodka View Post
    the cheapest group3 SP in my mini-stash is repsol leader. official api certs, look it up in the database. i paid 1950 for two 4L jugs, cashback is 150
    this pricing is in line w/ supertech/accel pricing so i expect it to be about the same quality. plenty of other options between this and OE pricing.
    I'm not seeing any Repsol 5w30 API SP.
    So I'm guessing this 10w30 is the oil you are referring to? The 2 jugs for P1950 deal might have been a promo? Because I'm seeing 345 a liter here:
    Repsol Leader Neo API SP 1W3 1% Fully Synthetic | Lazada PH
    #6492
    Oils. I just follow factory specs & change every 5k km or the longest, annually...whichever comes 1st. Tropics, usage & traffic must be factored in. If an intended keeper sees mostly short & slow trips, biannual oil changes(regardless of distance covered) should keep the engine healthy looooonger.
    Sent from my SM-S901E using Tsikot Forums mobile app
    Feb 2014
    #6493
    Repsol Leader Neo API SP 1�W3� 1��% Fully Synthetic | Lazada PH
    oh look it earned 390 cashback my bad
    Feb 2014
    #6494
    SP din yan
    Jun 2013
    #6495
    if its that cheap, makes me wonder why you or the other "mineral" guys here would still opt for conventional oil.
    too bad its 10w30
    Feb 2014
    #6496
    too bad its 10w30
    force of habit lang yan. if you've been successfully using brand X mineral for decades then why change now
    also the actual performance differences between an api SN mineral vs an SN group3 "synthetic" probably isn't as big as you think. against GTL or PAO then maybe the gap widens. coz "synthetic" is now just a marketing term, not a technical spec, so who knows what "synthetic" actually means
    btw what's wrong with "10w"? it's actually better if you're in PH than 5w
    Jun 2013
    #6497
    So it's basically a simple case of "you can't teach old dog new tricks".
    You say the difference isn't big between conventional mineral and group 3 hydrocracked "synthetic" oils, but why is it that manufacturers recommend using the latter in turbocharged engines? Like in subaru's manual, it specifically written there to use synthetic oil. I looked at the specs of Subaru's synthetic idemitsu oil its most likely a group 3 oil
    And how exactly is 10w better in the Philippines? 5w40 pa, I know its better for heat and aggressive driving
    #6498
    So what can you recommend third party engine oil for the 5th gen CRV diesel? Stock is 0W-16.
    #6499
    Honda Oil, Ravenol EFE or FEH has low Noack volatilty rating. The latter 2 are PAO synthetics, too.
    #6500
    Honda Oil
    Yes, still using OEM but based on manual I can use 5W-30
Mineral , semi synthetic or fully synthetic?
