Results 5,401 to 5,410 of 6542
- Aug 2011
- 162
April 4th, 2018 05:51 PM #5401
- Aug 2011
- 162
April 4th, 2018 05:55 PM #5402
April 4th, 2018 05:58 PM #5403
I've heard that for a very old car, they do not recommend a fully synthetic oil. One explanation they offered is that the oil "will not stick fully" to the cylinder walls. A very old car will not benefit from this since you will lose lubrication. Newer cars, according to them, has very small clearances that with such viscosity it will be better to use synthetic oil.
Let's wait for the experts here to confirm this.
April 4th, 2018 06:08 PM #5404
No significant difference ang 5w30 and 0w40 sa performance or longevity ng engine. Better fuel economy ang w30 since its thinner.
Your manual should state that you adjust your oil viscosity accordingly sa ambient temperature and conditions.
But remember na summertime na sa atin so papalo ng 40s ang temperature natin so better ang w40 oil. Thats what im using now for summer. For -ber months i use w30. Actually i get the same FC sa 2 oils with my Starex.
- Jul 2016
- 237
April 4th, 2018 06:08 PM #5405Ah nakalagay sa manual na 5w30 oil lang talaga at wala ng iba? If that’s the case I’d stick with what the manual recommends.
Usually kasi kahit na may suggested oil weight sa manual, may mga suggestion padin na ibang oil weights if ever not available yung unang recommendation.
Example:
- Aug 2011
- 162
April 4th, 2018 06:12 PM #5406The range stated is only 5w20, 5w30, 10w30, 15w40 & 20w50
- Jul 2016
- 237
April 4th, 2018 06:13 PM #5407
- Aug 2011
- 162
April 4th, 2018 06:18 PM #5408Shell Helix Ultra 0W-40 provides:
Unsurpassed sludge protection – no other motor oil can keep your engine closer to factory clean 1
Low viscosity and low friction characteristics for up to 1.9% greater fuel economy
Superior wear and corrosion protection
Easier cold starting
For gasoline, diesel and gas engines; also suitable for biodiesel and gasoline/ethanol blends
Specifications: API SN/CF; ACEA A3/B3, A3/B4; MB approval 229.5; VW 502.00/505.00; Porsche A40; Renault RN0700, RN0710. Meets the requirements of Fiat 9.55535-Z2
Taken from: Access Denied
- Jul 2016
- 237
April 4th, 2018 06:20 PM #5409
April 4th, 2018 06:22 PM #5410
Xiaomi E-Car
