Results 5,071 to 5,080 of 6580
- Aug 2012
- 2,767
August 14th, 2017 11:56 PM #5071API SN, ILSAC GF-4, ACEA A3/ B3, MB 229.1 (SAE 0W-40)
PTT Philippines Corporation - Products and Services
Sent from my ASUS_X00DDA using Tapatalk
- Apr 2014
- 473
August 15th, 2017 12:24 AM #5072
August 15th, 2017 12:55 AM #5073
its API-SN lng pala and MB229.1(this is an old old MB approval).
Mitasu MJ-112 is better than this. I think its 200 pesos more? I'm not sure.
SPECIFICATIONS / APPROVALS
∙ API SN/CF
∙ ACEA C3-10
∙ ACEA A3/B3-08
∙ ACEA A3/B4-08
∙ GM dexos 2
∙ PORSCHE A40
∙ BMW Longlife-04
∙ MB Approval 229.31
∙ MB Approval 229.51
∙ RENAULT RN0700/RN0710
∙ FIAT 9.55535-S2
∙ FORD WSS-M2C-917-A
∙ VW 502.00/505.00/505.01
- Oct 2004
- 278
August 20th, 2017 12:08 AM #5074Meron... Matagal ko nang gamit Redline oils (kaso sa gasoline engines, di ko pa nasubukan on diesel engines). I like 'em better than Motul (H-tec lang, can't afford 300V, hehe).
AFAIK, lahat ng Redline engine lube oils ay Group V.
I buy Redline oils sa Autotech (#2000 Singalong, Manila)... In between Quirino Ave. and San Andres. Try to give them a visit or call 02-4043594.
- Jul 2009
- 2,618
August 20th, 2017 12:19 AM #5075
August 20th, 2017 03:36 AM #5076
mobil1 new life 0w40
best oil in the business. even ceratec cant improve it🤣. found a supplier 6000/12liters. imported from france
ceratec works on less capable oils...
Ceratec Liqui Moly How well the oil additive protect the engine? 100
Sent from my SM-G935F using Tsikot Forums mobile appLast edited by StockEngine; August 20th, 2017 at 03:39 AM.
August 20th, 2017 09:11 AM #5077
I've read in many literature and videos that the 'one-armed bandit' test is irrelevant on engines. It is said that even the Head & Shoulders shampoo, due to its high zinc content, would easily pass the test. This is to say that there's more than one testing standard for motor oils and oils passing the one-armed bandit test does not signify it will perform well in all other, more relevant tests.
- 54,226
August 20th, 2017 09:25 AM #5078ang nagpa-popular nang one armed bandit tester na yan dito, ay si per'tua.
my question is, what happens when high metal temperature and high pressure come into the equation?
i wonder...
how does mane n tail do in that test?
- Mar 2010
- 2,275
August 20th, 2017 09:28 AM #5079
- Oct 2004
- 278
August 20th, 2017 12:58 PM #5080Ang alam kong usual na available sa Autotech ay 5W-30/5W40/5W-50/10W-30/10W-40/15w-40(CJ-4). P600/quart last na bili ko (baka nagtaas na ulit).
Meron ring mga gear oils (even for LSDs)...
Red Line Synthetic Oil - Motor Oil
Red Line Synthetic Oil - Technical Files
Anong Chinese brand na ba ang available sa market? Yung Leoch brand may nakita na ko post sa FB....
