Results 4,651 to 4,660 of 6542
September 22nd, 2016 04:09 PM #4651
- Jul 2013
- 2,450
September 22nd, 2016 04:33 PM #4652Ang assumption sa atin kasi ay may leaks na ang old engines. Low viscosity oils (thinner) is able to seep easily out of the engine through the leaks. Kung okay naman ang seals ng engine, wala naman siguro masama gumamit ng thinner oil.
Recommended oil for an engine does not change IMO. But bear in mind that higher rating for oil is usually backward compatible.
- Aug 2015
- 862
September 22nd, 2016 04:50 PM #4653Ang assumption sa atin kasi ay may leaks na ang old engines. Low viscosity oils (thinner) is able to seep easily out of the engine through the leaks. Kung okay naman ang seals ng engine, wala naman siguro masama gumamit ng thinner oil.
when I read the article ung Hx3 kasi 20w-50 yan. I've used Gulf 20w-50 before by mistake, and grabe ang ingay ng makina. Performance was still the same, sobrang ingay lang talaga, hindi tama. Nung nagpalit ako, sabi nung mekaniko ang lapot daw sobra LOL.
September 22nd, 2016 05:06 PM #4654
September 22nd, 2016 05:11 PM #4655
Kahit Anong oil pa Yan as long as ok yun viscosity for you and you change oil regusrly, I don't see any problem.
- Aug 2015
- 862
September 22nd, 2016 05:16 PM #4656
September 22nd, 2016 05:19 PM #4657
September 22nd, 2016 06:33 PM #4658
- Apr 2016
- 130
September 26th, 2016 10:05 PM #4659I think you need a higher viscosity oil when u have like a turbo charge cars or suv since they breath more air means more combustion so more heart, as for my mazda 3 1.6 2008 (ford engine) recommended ung 5w-20 but since sobrang nipis nun Id rather changed it to 5w-30.
I used shell helix (blue bottle) 5w-40 last may, and okay naman siya but i think may restriction since its thick for the recommended viscosity of my car so i tried to find a -30 and luckily i have, its MOBIL1 0w-30 so i just changed it today and will see how it performs from cold start tomorrow since pupunta akong QC hall :D well its just my opinion dont go below -30 just to be safe
- Sep 2016
- 50
October 2nd, 2016 07:13 PM #4660Sa amin, we use semi-synthetic shell oil (Diesel) and we change it every 4.5k-5.5k (On average 5k) whenever may budget at may oras na but usually we don't let it go as far as 6k. We maintain to change it every 5k kilometers or a few hundred more.
Ang nakikitang kong positive ng PPF is if the time comes to sell your car, you can remove the PPF....
Ceramic Coating vs PPF (Paint Protection Film)
