Page 649 of 659 FirstFirst ... 549599639645646647648649650651652653 ... LastLast
Results 6,481 to 6,490 of 6585
    #6481
    I literally just bought a gallon (4 quarts) of Amsoil OE for only 1.9k in shopee.
    I'm under the impression that some people here may have confused Fully Synthetic oil for Boutique Oil
    Confused na din ako. Paki explain diffeence
    di ako nag google
    ang pagkaintindi ko sa "boutique" oil is that your car's engine requires motor oil that's so special and rare that producers don't bother to make in large quantities coz the market for it is too small
    sadya bine-blend ang oil na yan by specialty shops kaya "boutique"
    kung motor oil mo nabibibili sa auto supply / gas station / shopee hindi boutique yan
    kahit synthetic pa yan
    Jan 2009
    #6483
    di ako nag google
    Yup, this is more accurate. I guess the term evolved to also mean expensive/exotic oils, kahit na available sa retail channels.
    Feb 2014
    #6484
    linis ah. what mineral oil is that? every when ang oil change? odometer reading? daily route? what car is that? ever had engine flush prior to this?
    by the way, no one here recently mentioned boutique oils so I dunno what's that about.
    150,000+ km. never had engine flush. honda oil, havoline formula, valvoline premium conventional, all the cheapest 10w30 oils less than 1k. 6mo oci, then later on 1yr oci
    Jun 2013
    #6485
    Quote Originally Posted by Vodka View Post
    Info is from 2006
    I don't consider Amsoil OE oil as boutique oil, ****'s dirt cheap for a synthetic oil.
    Amsoil's Signature Series oil, now that's a different story.
    I tend to agree with the other posts here, I consider boutique oils as those expensive oils with unique properties or other gimmick like extended drain interval or for intended for racing. Some are even not API certified like Redline and Amsoil Signature
    Feb 2014
    #6486
    Info is from 2006
    they're not api certified coz some components exceed api limits, in an effort to extend drain intervals
    but yeah amsoil OE isn't boutique (it's a post 2006 product). in fact there's nothing special about OE, it's just some run of the mill oil. pure group3 bitog says it's about the same caliber as supertech. in other words you're paying about twice for this mediocre oil. in that way you could consider it boutique LOL
    i'd consider PAO as boutique, as well as GTL gas to liquid like those expensive shell oils
    Jun 2013
    #6487
    Try running conventional mineral oil instead of group 3 hydrocracked oil in a modern turbocharged engine and see how it goes.
    Feb 2014
    #6488
    plenty of api SP group3 that are cheaper than amsoil OE. maybe even better than OE SP na yan pang turbo GDI
    but that's not my problem my NA engines are going to be fine w/ Accel. i think i'll buy more of those. 1000 pesos, 4 quarts, made in USA by warren. can't go wrong
    Jun 2013
    #6489
    And what oils are those? Do tell.
    Feb 2014
    #6490
    the cheapest group3 SP in my mini-stash is repsol leader. official api certs, look it up in the database. i paid 1950 for two 4L jugs, cashback is 150
    this pricing is in line w/ supertech/accel pricing so i expect it to be about the same quality. plenty of other options between this and OE pricing.
Mineral , semi synthetic or fully synthetic?
