Results 6,151 to 6,160 of 6542
September 26th, 2020 01:15 AM #6151
Not all marketed 'Synthetic' are really such. API classifies GroupIII refined mineral as 'synthetic'. Most US brands mark their GroupIII as FS....they're commonly available & more affordable.
GroupIV PAO based is the true synthetic...most are Euro/German. Less common & pricier. Mobil 1 used to be PAO, the US-blend isn't anymore. Group IV synthetic base stocks generally have very low evaporation loss numbers and high for shear testing.
BANNED BANNED BANNED
- Sep 2015
- 13,919
September 26th, 2020 01:35 AM #6152
- Sep 2015
- 13,919
October 15th, 2020 02:29 PM #6153sa car user's manual ng veloster nakalagay pag 5w20 engine oil eh hinid pwede gamitin sa middle eastern country
eh ang pinas halos ganyan temperature pag summertime.
October 15th, 2020 03:03 PM #6154
The Middle East is dry heat, not the humid type of heat we have here. The same thing in desert areas like Arizona and Southern California - dry with very limited moisture.
Sa manual naman may nakasulat kung ano yung alternative viscosity. Honda uses 0w20 FS oil for their gas cars here but you can also opt for 5w30. Ford suggests 5w20 or 5w30 for their gas vehicles. Subaru uses 0w20 for non-turbo and 5w30 for turbo.
- Sep 2015
- 13,919
October 17th, 2020 05:42 PM #6156
- Sep 2015
- 13,919
October 17th, 2020 06:53 PM #6157^
dexos parang same sa LS oil (low sulfur)
sa facebook ko yan nakita parang nasa 450.
- Sep 2015
- 13,919
October 17th, 2020 11:32 PM #6159Nakita ko na yung 450pesos
Facebook ? log in or sign up
ZIC 5w30 dexos 1 Fully Synthetic X9
₱450 · In Stock
Listed 8 hours ago in Quezon City, National Capital Region
October 26th, 2020 07:06 PM #6160
I am currently using Kixx PAO C3 5w30 diesel oil in my dpf equipped crossover. It is not pure PAO but a combination of Gr III & PAO. It isn’t too expensive at P1,500/4 lits. Car is currently running 5k+ & going 5 months with this oil & oil still looks like its not saturated. I plan to change the oil & filter at 7,500 kms to the same brand & type at 5w40, in anticipation of higher temps. I rarely get stuck in heavy traffic anyway & mostly do long extended runs whenever I get the chance.
I am planning to get Cyclon brand FS Gr III 5w40 next, also ACEA C3. Not too pricey also at P1,750/4 lits.
high idle RPM at engine start
