Results 6,051 to 6,060 of 6542
- Jan 2007
- 2,234
August 13th, 2019 10:46 PM #6051
August 13th, 2019 10:52 PM #6052
August 13th, 2019 10:56 PM #6053
oil is for lubrication at temps. they are designed to withstand heat.
cause of fire could have been overloaded electrical wires or fuel related... they must have been working on a fuel pump. .
- Jul 2009
- 2,618
- Jul 2009
- 2,618
August 14th, 2019 01:52 PM #6055
- Nov 2019
- 4
November 7th, 2019 05:18 PM #6056Good day! 1st post here, been reading forums since I've purchased our vehicle. Would like to ask for your feedback regarding OCI for our vehicle...
Vehicle: 2013 Hyundai Accent Hatchback CRDi
Odo: 29k
Last PMS: 20k
Previous Oil Used: Total Gold 9000 Diesel 5W30
Question po is:
- Is it OK to extend the OCI to say 15TKMs? Budget's currently tight for OC and will probably be able to do OC on December before Christmas.
- Car's only used on weekends with route of Bulacan-Laguna-Bulacan with several long-distance trips like La Union, Baler, Baguio.
- Travel time is always early morning (4AM-6AM) and late night-early morning (11PM-4AM) where traffic is light.
- Can I extend said PMS?
- Vehicle is maintained in a Nissan dealership (which also services Hyundai vehicles since they own a Hyundai dealership in Manila) and OCI usually consists of Oil Change, Oil Filter change.
Thank you!
November 7th, 2019 05:35 PM #6057
If I may, cause I own the same car, albeit with a higher mileage. I presume you do a 10k pms sched of pms. Even if you rarely use your car, 10k is 10ks worth of running time. Meaning, it is time for an o/c, filter change. Have you seen how dirty the oil is at 10k? Full of soot. At 10k, you will also have to change/clean the engine air filter, clean the brakes, rotate tires & others. Why not just buy the oil filter from hyundai (P600+-) & Zic oil FS (6 lits at P1,600 +-) from Lazada & just have it serviced outside?
- Jul 2009
- 6
November 13th, 2019 06:44 AM #6058My old 2011 Fiesta is using Shell Helix in the casa since day 1 and I always notice a slight oil burn smell (sensitive nose) after around 4000 RPM. I thought it is the norm so I don't usually exceed that RPM unless I don't have a choice. Around a year ago, I DIY and bought Amsoil in Lazada with Bosch filter and just did the oil change in Motech since it is just hundreds of meters away from our house. I did not expect much but lo and behold, initially I thought 4000+ RPM without any burning smell is cool. The engine sound is better too, maybe due to its Yamaha roots it's trying to encourage you to rev up more and more so I ended up 5000 max then one day hit 6000 RPM red line (yeah you won't notice it). Still no oil burning smell and no ill effects so far, did not expect me enjoying the old car 7 years after. My FXT is fed with Motul and can't wait to switch to Amsoil after warranty expires. Tried to but it is a long story. Was also not surprised that Amsoil won the Project farm youtube channel oil championship mid this year. Now I wonder how Amsoil will perform in a K24 engine revving 7000 RPM. I bet it will be more fun than my two cars combined lol.
November 13th, 2019 01:09 PM #6059
November 13th, 2019 01:13 PM #6060
high idle RPM at engine start
