Page 556 of 659 FirstFirst ... 456506546552553554555556557558559560566606656 ... LastLast
Results 5,551 to 5,560 of 6585
    it was washer fluid.. female owner put it in the wrong hole [emoji28]
    it was a mini...
    Apr 2012
    #5552
    it was a mini...
    i wonder how they will clean the gunk [emoji848]
    #5553
    Sakin bro, yun cleaning nun gunk madali lang
    After surface cleanup, pwede spray nalang ng forgot the chemical name, pero tipong brake cleaner, after washing nga with detergent
    Kung matagal nya nagamit yan, baka di makuha sa overhaul
    Sent from my SM-C900F using Tapatalk
    Apr 2012
    #5554
    i see, madali siguro sa cleaning agent o spray sa mga outer surfaces but how about sa mga nook and crevices at linya ng oil? total baklas malamang yan
    total na bro...the small journals cannot be cleaned..
    Jan 2009
    #5556
    Not to mention the metal-to-metal damage the engine sustained when the oil turned to mud. I bet the engine already started knocking, overheated or seized up before they figured out the mistake.
    Apr 2012
    #5557
    Used this last Wednesday for my change oil. Costs 1600/6L gallon and 300/L.
    Sa goodgear ko nabili
    Sent from my SM-J730G using Tapatalk
    #5558
    Sa Goodgear karin ba nagpa change oil?
    Apr 2012
    #5559
    Hindi sir, sinabay ko na dun sa shop na nagpalit ng shocks
    Sep 2017
    #5560
    Ever heard of platinum oils? dami nyang approvals. Sa lazada enticing presyo nya. Nasa 1300 lang ung isang gallon.
    Product details of Platinum Formula Syn Fully Synthetic Engine Oil - SAE 5W-30 API SN & CJ-4 - 4pcs x 1 Liter
    FORMULA SYN 5W-30 is today’s most up-to-date engine oil formulation technology providing the highest degree of protection, engines cleanliness, extended drain interval, and fuel economy.
    PRODUCT BENEFITS
    APPLICATIONS FORMULA SYN 5W-30 is designed for use in all types of gasoline-fueled vehicles including the latest 2012 models with performance rating even up to API SN . The new technology formulation also meets the requirements for diesel-fueled passenger vehicles requiring performance rating even up to API CJ-4 .
    APPROVALS
    API SN, SM, SL, CJ-4, CI-4 PLUS, CI-4, CH-4 ACEA A3/B3-08, ACEA A3/B4-08, ACEA C3-10
    BMW LONGLIFE-04 GM DEXOS 2
    MB P299.31 PORSCHE
    ILSAC GF-5, GF-4 VW 502.00 / 505.00
    FORD WSS-M2C946-A & WSS-M2C929-A CHRYSLER MS-6395
    VOLVO VDS-4 RENAULT RLD-3
    CAT ECF-2/ECF-3 CUMMINS 20081
    eto website nila SYNTHETIC - PLATINUM OIL
Mineral , semi synthetic or fully synthetic?
