enoc is another brand. iba ang ardeca
Ardeca po ito sir enoc is from malaysia ardeca from belgium. Po sa makati po magallanes commercial center po.
Sent from my SM-J700H using Tsikot Forums mobile app
Thank you. Ardeca lubricants will cover all in the philippines.
Nag parating ako pro-tec ultra 10w30 sir. Pero 5w30 sir sa diesel medyo manipis kasi kaya recomment namin mataas vescocity sa clima natin sa pilipinas.
Let me know if gusto nyo po. Kami po distributor sa pilipinas sir ng ardeca.
Any feedback on PTT Performa Super Synthetic SAE 0W-40 gas engine oil? 4L bottle is P1,900.
Sent from my ASUS_X00DDA using Tapatalk
Wow 0W40 most likely a grp3 and grp4 base oil. Does it have BMW LL01 approval? It would still be ACEA A3/B4 I would assume, which is good for extended oil drain intervals.
API SN, ILSAC GF-4, ACEA A3/ B3, MB 229.1 (SAE 0W-40)
PTT Philippines Corporation - Products and Services
its API-SN lng pala and MB229.1(this is an old old MB approval).
Mitasu MJ-112 is better than this. I think its 200 pesos more? I'm not sure.
SPECIFICATIONS / APPROVALS
∙ API SN/CF
∙ ACEA C3-10
∙ ACEA A3/B3-08
∙ ACEA A3/B4-08
∙ GM dexos 2
∙ PORSCHE A40
∙ BMW Longlife-04
∙ MB Approval 229.31
∙ MB Approval 229.51
∙ RENAULT RN0700/RN0710
∙ FIAT 9.55535-S2
∙ FORD WSS-M2C-917-A
∙ VW 502.00/505.00/505.01
Meron... Matagal ko nang gamit Redline oils (kaso sa gasoline engines, di ko pa nasubukan on diesel engines). I like 'em better than Motul (H-tec lang, can't afford 300V, hehe).
AFAIK, lahat ng Redline engine lube oils ay Group V.
I buy Redline oils sa Autotech (#2000 Singalong, Manila)... In between Quirino Ave. and San Andres. Try to give them a visit or call 02-4043594.
mobil1 new life 0w40
best oil in the business. even ceratec cant improve it🤣. found a supplier 6000/12liters. imported from france
ceratec works on less capable oils...
Ceratec Liqui Moly How well the oil additive protect the engine? 100
I've read in many literature and videos that the 'one-armed bandit' test is irrelevant on engines. It is said that even the Head & Shoulders shampoo, due to its high zinc content, would easily pass the test. This is to say that there's more than one testing standard for motor oils and oils passing the one-armed bandit test does not signify it will perform well in all other, more relevant tests.
ang nagpa-popular nang one armed bandit tester na yan dito, ay si per'tua.
my question is, what happens when high metal temperature and high pressure come into the equation?
i wonder...
how does mane n tail do in that test?
Ang alam kong usual na available sa Autotech ay 5W-30/5W40/5W-50/10W-30/10W-40/15w-40(CJ-4). P600/quart last na bili ko (baka nagtaas na ulit).
Meron ring mga gear oils (even for LSDs)...
Red Line Synthetic Oil - Motor Oil
Red Line Synthetic Oil - Technical Files
