Page 401 of 658 FirstFirst ... 301351391397398399400401402403404405411451501 ... LastLast
Results 4,001 to 4,010 of 6580
    very well said bro
    i'm actually leaning towards trying out mitasu for my next oil change. tingnan natin kung ayos fully synth nila
    very well said bro
    Most oils are good. Depende sa maintenance ng owner. oil change interval and age ng engine, coolant maintenance etc.
    #4002
    Quote Originally Posted by Sebastian Bach View Post
    Sirs, need your professional opinion, my ride has a PMS interval of per 5K odo reading, but mine takes about 7-8 months to reach that 5K. I used Regular oil on my last PMS, should I stick to that or use Fully Synthetic oil instead? Medyo matagal ko kasi ma reach yung per 5K sa odometer. Though I use my ride everyday.
    i'm an average joe driver.
    i use mineral oil.
    i take my time to reach 5K, then i change oil.
    ... been doing it for decades.. wala naman problema.
    Jul 2015
    #4003
    We went to La union this weekend, few days before that i changed my oil to motul and tried a different vicosity, thicker than the recomended 5w30, just a precaution, i know i was driving in the 3k-6k rpm most of the time....oil temp never went up above 103 C, added a can of ceratec...just to be on the safe side
    Jun 2015
    #4004
    Quote Originally Posted by Stock Engine View Post
    Use semi synth
    i use mineral oil.
    Thanks!
    Aug 2012
    #4005
    very well said bro
    very well said bro
    Be sure to get the Gold/Platinum variant, PAO based sya at SN rated pa. Sure na okay yan bro. I heard 2,600 daw ang 5w-40 na platinum. Price is not bad considering the oil's specs.
    Aug 2012
    #4006
    I'm assuming most of your trips are very short. You can stick with mineral oil but I advise you change it every 6 months, mas prone kasi sa sludge at carbon buildup ang mga sasakyan na puro short trips.
    Quote Originally Posted by Troy Inovero View Post
    Grp3 or grp4 base oils dont matter much nowadays. These discussions died years ago in bobistheoilguyforums. Most oils have good additive packages that meet most manufacturer requirements. Simply following recommended oil changes and engine requirements are the common discussion now. New topics now are direct injection engines and fuel dillution and ecoboost stuff.
    #4008
    Just replace your oil every 5k kms,
    Jun 2015
    #4009
    Mga around 25km per day. Alright. Thanks!
    Dec 2012
    #4010
    So hard to backread, I'll just ask tsikot gurus directly. If a vehicle uses synthetic oil, then it should be synthetic all the way? I cannot go back to mineral oil? if the answer is a big NO then i'm good. If I can go back then my next question would be is there a detrimental effect when I switch back to mineral. thanks!,
Mineral , semi synthetic or fully synthetic?
