Page 196 of 330 FirstFirst ... 96146186192193194195196197198199200206246296 ... LastLast
Results 3,901 to 3,920 of 6586
    Jul 2015
    #3901
    Quote Originally Posted by dct View Post
    245 zic
    440 mobil 1
    No contest ang layo ng price. Mag zic ka.
    Paired with baldwin, pwede rin ba 10k km interval ang change oil with zic? Ganyan kasi gawa ko sa mobil 1
    Sa gasoline engine sisiw yan 10,000kms,
    Pero sa diesel practice namin sa negoyso around 7,500kms nagpapalit na. So not too early not too late ang palit ng oil.
    Jun 2012
    #3902
    Quote Originally Posted by amoyligo View Post
    Thanks for inputs sir. Kahit pa baldwin ang oil filter? Delikado ba 10k para sa zic oil?
    May 2009
    #3903
    Sa API yung CI-4 CH-4.
    Wag CF-4 sayang pera. Jurassic na yan rating.
    Dexos 2 pwede either gasoline or diesel engine.
    pero CF-4 yung mineral oil ng toyota para sa mga D4D. so depende pa rin sa requirement ng manufacturer.
    Jul 2015
    #3904
    Hindi sa brand ang basehan kung pwede 10,000kms. Pag rated ci-4 eh long drain interval yan so pwede mo paabutin 10,000kms.
    Pero sa negosyo eh practice na namin lalo na pag diesel hindi isagad ng 10,000kms. Mura lang namin nakukuha by the drum kaya around 7,500kms pinapalitan na kahit pwede patagalin.
    Pag magbasa kayo ng article about oil ang focus ng usapan api rating, viscosity at lastly base oil.
    Jul 2015
    #3905
    Quote Originally Posted by miked View Post
    Yan yung minimum rating na pwede mo gamitin para sa d4d.
    Pero CH-4 CI-4 ang maganda ngayon sa majority ng diesel engine dito philippines.
    Aug 2012
    #3906
    Anyone tried using 0w-20 oil in their cars? Particularly Honda. Hindi kaya sya masyadong manipis at operating temperature? May nag ooffer kasi sakin ng ganun na oil. Currently using Idemitsu Extreme Eco 5w-30.
    Jul 2015
    #3907
    Sa mga year 2012 honda model yan na pinapagamit casa.
    Pero kung ako hanggang 5w30 lang pinakamanipis gamitin ko dito sa country natin.
    Mar 2015
    #3908
    https://youtu.be/O1hF25Cowv8
    You brought shell? Helix Ultra? Thats fully synthetic oil. its one of the best oils.
    Shell Helix Ultra is fully synthetic(silver bottle)
    Shell helix HX7 semi (blue bottle)
    Shell helix hx5 premium multigrade (yellow)
    Sir eto po yun oil na gamit ko. D ko po kasi gaano naintindihan sir yun mga rating e. Pasensya na po. Basta sabi po kapatid ko ito daw lagay ko e. imageuploadedbytsikot-forums1439993747.002886.jpg
    Mar 2015
    #3909
    Quote Originally Posted by midnytwarrior View Post
    Kung makakahanap ka ng oil na 10w30 na synthetic, or Castrol Edge na 10w-30(not sure if meron dyan sa atin). Make sure to buy sa mga reputable na sellers and at least check mo if API SN na sya para at least bago yun oil. Kung may naka stamp na manufacturing date mas OK.
    Thank you sir sa reply will look for this sir. Try ko sa next 5k change oil ko po. [emoji4]
    Mar 2015
    #3910
    Oo yun ang mas current sa API.
    Pero kung gusto mo linisin makina mo mag CI-4/SL ka 10w40 or 10w30. Bihira naman kotse sa pinas na minimum API SN. Majority SL SM pa.
    Wag 15w40 or 20w50 lapot nun gagaspang takbo.
    Will do sir thank you! Parang ok po yun castrol try ko po ito next change oil po.[emoji4]
    Mar 2005
    #3911
    Quote Originally Posted by Troy Inovero View Post
    Sa Honda yan recommended nila. Checked my Sonata 2012 and ganyan din recommended as per manual pero hindi sa Casa. 5w30 na lang para sure.
    Mar 2012
    #3912
    I always thought that oil never expires until i read this. So I checked my leftover containers. Honda SS oil has 2014 printed on it, no indication if it is manufacturing or best before date. However it did feel good on my engine. The other one was Mag1 FS, unfortunately the printed numbers were almost worn out so can't get anything from there. it's currently on my engine for 1k kms now and it feels a bit rough compared to the Honda. Both are SN rated.
    Lahat ng engine oil meron manufacturing date. There is a shelf life for these oils.
    Sep 2013
    #3913
    I've tried several times using expired FS oil 3 years from the mfgt date. so far nothing bad happened to the engine. What's the effect of using expired oil to engine?? TIA
    #3914
    Used the Honda 0w20 "Green" oil with our City and Jazz (2009) and they worked just fine. Warm-up time is faster compared to the older Vtec LEV 5w40 oil. Mahirap i-source sa labas pero mayrun mapagkunan. I might even consider using it on my Fiesta Ecoboost if I'm out of warranty already.
    Quote Originally Posted by kimbon View Post
    5yrs is the shelf life as per some manufacturers.
    Dec 2009
    #3916
    20 is better than 30, new engines have tight clearance hence it wont need a thick layer of oil for protection. A thin layer will do
    In addition thin oil spread out much faster than thicker oil providing more protection to the engine components
    Try lifting the oil stick & invert it for you to visualize how swift the oil spread & cover the metal part of the stick
    Aug 2012
    #3917
    Thanks sa mga reply nyo amoyligo/jmpet626/Egan101,kisshmet
    Kung sakaling ituloy kong gamitin yung 0w-20 ng Honda, mas okay kaya kung magpalit nadin ako ng oil seals?
    Jul 2015
    #3918
    Sa pagkaalala ko kasabay ng honda civic FB year 2012 yung 0w20 naintroduce locally.
    Sa year 2012 model-present like the new jazz, city, mobilio, hrv, crv try nyo.
    No need to change oil seal kung hindi pa naman due.
    Aug 2012
    #3919
    2012 po yung jazz ko sir pero hesitant parin talaga ako sa 0w-20. hindi rin kasi sya nakalagay sa manual e. Dati kasi natry ko maglagay ng oil na 20w-50 dahil wala pa akong gaanong alam nun, di ko napansin na hindi pala recommended yung ganung viscosity sa manual, saka hindi ganun kaganda yung andar ng kotse kaya after 2 months lang nagpalit ako ulit ng langis. Honda FS na 5w-40. And nakapagtry na din ako ng Motul H tech 100 10w-40 at motul multi standard 5w-40. Pero yung 30 grade na idemitsu talaga pinakanagustuhan ko.
    30 at 40 grade lang nakalagay sa manual kaya feeling ko masyadong manipis talaga yung 20 at yung 50 naman ay masyadong makapal.
    Aug 2012
    #3920
    Share ko lang yung nabasa ko.
    Viscosity is the measure of how thick an oil is. This is the most important property for an engine. An oil with too low a viscosity can shear and loose film strength at high temperatures. An oil with too high a viscosity may not pump to the proper parts at low temperatures and the film may tear at high rpm.
    The viscosity of liquids decreases as temperature increases. The viscosity of a lubricant is closely related to its ability to reduce friction. Generally, the least viscous lubricant which still forces the two moving surfaces apart is desired. If the lubricant is too viscous, it will require a large amount of energy to move (as in honey); if it is too thin, the surfaces will come in contact and friction will increase.
    Nabasa ko rin somewhere na yung Mobil 1 na 0w-40 ay one of the best oils dahil manipis/magaan sya sa startup at okay din kapag operating temp na dahil 40 weight sya. Kumbaga you get the best of both worlds.
Mineral , semi synthetic or fully synthetic?
