Quote Originally Posted by jinrai View Post
dami pa rin nag papa general overhaul e.. i guess di sya kasing effective as claimed?
Ofcourse overhauling di talaga mawawala yan....Xado will just fix clearances and wore out cause by metal to metal friction..Lahat ng clearance sa cylinder wall ( Liner ) at ring magbebuild up sya ng cermet ( ceramic metal )....atsaka mga wore out bearings sa engine moh..that why when you use xado, you'll notice a quiet engine, no excessive smoke sa exhaust, mataas na compression at oil pressure,more power and fuel efficiency about 15% to 30% ..Xado never over build up...Xado can not fix leaks from valve seal, oil seal or rubber gaskets...
We still need overhauling pag naputol ring or once maputolan ka ng timing belt....
