Results 91 to 100 of 104
- May 2004
- 903
June 6th, 2008 10:59 AM #92
this is what it looks like...i've tried the power steering gel and now we are under process to complete the procedure of the gel.. So far for the 1st gel..I noticed the smoke from my exhaust disappeared. And the engine noise was reduced.
June 6th, 2008 11:24 AM #93
may thread na about this product way before those fancy packaging...
arang makailang gamit ka ata muna to have a real result..
June 6th, 2008 11:39 AM #94
Yes bro..3 tubes kailangan for 3 to 10 liters of oil..I follow the procedure talaga..pero before ka magstart, flushing muna with vitaflush...before at idling 20 lang ung oil pressure ko..ngayun 80 to 100...atsaka nawala na ung smoke sa exhaust ko..at meron nang power...
June 6th, 2008 12:06 PM #96
theveed,
I just merged the other XADO threads into one. Re-openned the merged thread.
June 6th, 2008 12:44 PM #97
WOW!!!! Its really hard talaga to prove everybody that this product works..Well, for me it works...Just try it yourself nalang mga bro..para kayo mismo makatestify...ako i try it, kasi subject for overhauling na sasakyan ko...I take the risk nalang...for me worth the risk namn..
June 7th, 2008 09:03 AM #98
Ofcourse overhauling di talaga mawawala yan....Xado will just fix clearances and wore out cause by metal to metal friction..Lahat ng clearance sa cylinder wall ( Liner ) at ring magbebuild up sya ng cermet ( ceramic metal )....atsaka mga wore out bearings sa engine moh..that why when you use xado, you'll notice a quiet engine, no excessive smoke sa exhaust, mataas na compression at oil pressure,more power and fuel efficiency about 15% to 30% ..Xado never over build up...Xado can not fix leaks from valve seal, oil seal or rubber gaskets...
We still need overhauling pag naputol ring or once maputolan ka ng timing belt....
June 14th, 2008 11:35 PM #99
Xado can really save your engine from costly repair...and also 15% fuel..heheheh
- Apr 2008
- 81
November 27th, 2008 03:36 PM #100xado ... mukhang wlang conclusion tong thread nato a? does it work or not? walang proof e pati yung supposed testing hindi rin natuloy? allanroy not posting anymore? hehe
If that's the case, then hindi rin pala lahat ng nakaka-afford sa kanila ay hindi frugal mag-isip...
2021 Toyota Land Cruiser LC300
