Results 1 to 20 of 28
    my ride is nissan lec.last month pina top overhaul ko yung kotse ko kasi mausok sya sobrang kapal at puti yung usok nya.pinalitan namin ng piston ring valve seal tensioner timing chain head gasket.sbi ng mekaniko ko after a week mawawala na yung usok so ginamit gamit ko muna yung kotse para matuyo yung mga langis daw na naipon sa loob.ngyon lagppas 1 month na hindi parin nawawala yung usok ganon padin tapos yung spark plug ko palaging na pupundi simula nung ginawa nya yung kotse ko nakaka 3 sets nako ng spark plug na bili.please help mga paps?
    May 2007
    Did you change the head gasket and the intake manifold gasket? Are you sure that the head is not crack or Cracked cylinder wall? See if water and oil are mixing inside the engine. This is what causes the smoke.
    In response to your additional details: Quit starting the engine. Have it towed to a shop! Everytime you start the engine, you're dumping more water into the cylinders, some of which gets into the oil and reduces the oil's effectiveness. The more you run the engine, the more you run the chance of damaging it. Good luck....
    hindi yata nyo pina crack check yung cylinder head?
    Nov 2006
    In times like this . . . baka mekaniko mo na ang kailangan palitan. :twak:
    But seriously replacing those things doesn't necessarily mean that you have solved the problem. As what V6 mentioned, check for leaks on the head and walls and refrain from starting the engine.
    Jan 2008
    Mabilis bang magbawas ng tubig sa reservoir o sa radiator. If (+) baka head gasket nga at bengkong na cylinder head.
    Ano ang amoy ng usok, amoy gasolina ba, matapang ba sa mata at ilong.
    Puting puti ba ang usok o bluish, kasi ba bluish maaring hindi maganda ang lapat ng piston rings at bores maaring di tama ang specs ng piston rings o di maganda ang break-in after the repair.
    Dahil palaging fouled out (napupundi?) ang spark plugs mo maaring di nga
    maganada ang lapat ng rings at bores. Yung valve guides wala ba diperensya.
    Di kaya mali ang kabit ng valve seals. Wala bang oil leaks sa paligid ng makina mo dahil sobra ang nalagay na engine oil causing excessive crancase pressure.
    Paano mo ba ginamit o break in kotse mo after the repair, kasi medyo mausok talaga sa simula pag ginalaw mo yung rings or bores but once na na-break in na e wala na rin mga oras nga lang e wala na driving it at moderate H-way speed. pero kung pa idle-idle lang di talaga lalapat ng mabuti ang rings kelangan ng heat to expand the rings and bore at ng maghasaan o magkiskisan sila ng maayos.
    Ask questions first. Analyze the answers and then give conlusions.
    Arvy,
    Paano ka nag break-in?
    Nag ooverheat ka?
    Nawawalan ka ng tubig sa radiator?
    Saan nilagay ng mekanic yung putol ng mga piston ring? I hope hindi sa isang location.
    Pinag aralan ba ng mabuti kung over size or standard ang gagamitin rings?
    Assuming eveyrhing was done right, baka hindi ka pa na fully breakin.
    wla naman po oil leak sa paligid ng makina.amoy gas po ung usok sakit din sa mata yung usok.meron po dito shop lapit samin along del monte ave. corner d.tuazon sbi nila tangal kabit daw nila ng cylinder head is 1,500yun yung labor nla puede din daw sakin mangaling yung mga kailangan kailangan na pyesa.sa tingin nyo po ba ok na yung ganitong deal?kesa sa ibang mekaniko ako magpagawa dito kasi sa shop na sinasabi ko pwesto talaga puede ko ibalik pag hindi padin nawala yung usok at pag pundi ng plugs ko.pls help po!tnx
    Dec 2020
    Quote Originally Posted by youngrider View Post
    Good day mga sir. Same problem here. Ang sa akin naman, dukot lang pero pinalitan lahat ang pistons at piston rings, head gasket, valve seals, manifold gasket pero yung sa exhaust lang. Sabi ng mekaniko okay pa naman daw ang bore at hindi pa kailangan ng liner. Ang ipinalit na rings e over sized. From standard to .25, tapos hinasa daw niya para lumapat. After magawa, mausok pa din. Ganun din ang sabi, after a week mawawala daw ang usok pero two weeks na sobrang lakas pa din ng usok. Hindi naman nahina ang hatak, hindi din nagbabawas ng tubig sa radiator at reservoir. Very smooth ang andar. Ang problema lang talaga e yung usok. Hindi naman amoy gasolina, hindi din masakit sa mata. Pundi daw ang isang spark plug kaya mausok pa din so pinalitan ko na din lahat, hindi pa naman napupundi as of the moment. Ano kayang diagnosis ninyo dito mga sir? Salamat sa mga sasagot at makakapagbigay linaw.
    nag palit po kami ng head gasket.yung manifold gasket hindi. puti po talaga yung usok ako po kasi pinabili ng mga pyesa na need namin sbi nya standard na sukat ng piston ring tska dala ko yung mga binaklas nya na pyesa sa store na binilan ko.tinanong ko naman sya kong ano lagay ng cylinder haed ko sabi nya ok pa daw.sa brea in naman po halos malalapit lang pinupuntahn ko.sa radiator po nagka leak nito nalang bago mapundi ung plugs ko pero before nung wla pa leak hindi sya nag babawas ng water.
    Jul 2006
    Quote Originally Posted by arvy View Post
    ......Maaring hindi tama ang pagkakalagay ng mga piston rings (nagaligned ang mga gaps ng rings kaya lumalabas ang oil going to the cyl head's exhaust. Isa ito sa maaring dahilan kaya maputi at mausok ang exhaust. Mabilis ba magbawas ng oil....kinikil pa ba ng mekaniko mo ang rings?
    hindi.nakita ko kasi nung kinabit nya.my nakita ako binebenta na ga14 na engine asking price nya 10k with papers and transmision.meron din 1 ga13 naman wla namang papers asking price nya 9k.ano sa tingin nyo buy nalang ako engine or pabaklas ko muna yung makina ko tpos pa estimate ko sa machine shop yung gagastosin ko?napapraning nako sa problema ng auto ko.
    Wag ka muna magisip ng gastos. Breakin mo pa. Drive it hard but watch your temperature. Its possible that your rings hasnt seated yet that is why oil still pass thru it. Wala naman katok diba?
    May 2007
    WHITE OR BLUISH SMOKE?
    It can be more easy to fix than you think did you replace the PC Valve? when that thing is bad the oil will jump from the valve cover to the intake.... burning more oil. Try it before to take out the cylinder head and check the pistons rings again, check the spark plugs to see what piston is burning oil.
    Well problema talaga, there are only two major possible cause, first maybe the rings were installed incorrectly, this would suck. The second option is the valve seals either were installed incorrectly or they were the wrong ones or they could have been faulty. Not every car part you buy is perfect and could have been flawed at the factory. Do a compression test if it is spot on its, probably not your rings. good luck
    Oct 2009
    dre, ang problema ng makina mo base sa kuwent mo ay kiailagang i overhaul uli kasi nagpalit nga kayo ng ring pero hindi na dapat original na piston ring ang dapat ikabit actaully kailangan nang i rebore ang engine mo at hindi na std ang piston ring. i recoment you have yo study at least basic mechanic im working in meralco foundation ortigas pasig
    Aug 2009
    elo mga paps,
    nakapagtry na ba kayo bu,ili ng parts online?
    may marerecommend ba kayo na site for buying parts online? balak ko kasing bumili ng b2200 engine para sa van namin. pero gas fed yun sakin unlike na commonly diesel for b2200 engines.
    or may mga shops ba kayo na marerecommend for general overhaul at kung magkano estimated na gagastusin?
    regards,
    chinese
    Mas maganda kung actual mong nakikita ang makina at magdala ka ng mekaniko na bihasa sa ganyang makina kesa on line .opinion lang.
    Hinasa? Nako.
    Dapat sakto ang palit. At kung naayos nya yan dati, dapat wala nang usok from the start.
    My bet, sira pa rin yan.
mausok parin pag tapos top overhaul
