Results 11 to 18 of 18
Tsikot Member Rank 5
- Nov 2003
- 3,849
May 13th, 2006 11:06 AM #11sure you can hang out if you want.
bring the head to the machine shop na competent para they can perform crack testing and see if pantay pa yung head. reface mo if necessary. buy an overhauling kit and replace all of the seals narin.
- Oct 2005
- 147
May 14th, 2006 07:24 PM #12Originally Posted by speedyfix
yup nakalas ko na yung head nag ruler and filer guage test lang ako for kung warp. so far injectors palang ang sure akong kailanagn ng replacement.
yung oil cooler ba ng mazda R2 puwede palitan pangit na kasi itsura eh. Siguro tingin ako sa surplasan kung merong maganda pa itsura para maski makina man lang mag mukhang show car.
- Oct 2005
- 147
May 15th, 2006 06:30 PM #13Hi all
Anu ba difference ng steel head gasket at asbestos. Tinanong kasi ako nung bumili ako ng headgasket pero dati usually steel ang binibili ko.
anung brand ng headgasket at injector ang recommended ninyo
thanks
,prysm
May 15th, 2006 06:50 PM #14Originally Posted by prysm_1
- Oct 2005
- 147
May 17th, 2006 07:31 PM #15
- 72
May 18th, 2006 09:00 AM #16oh btw, is it advisable to conduct an overhaul on an engine ngayon tag ulan ? di baka, kapitan ng kalawang ang mga exposed na bakal ng block ?
- Nov 2003
- 3,849
May 18th, 2006 10:11 AM #17just reclean it an put a layer of oil on the parts that are exposed to protect it.
- 72
high idle RPM at engine start
