Page 1 of 2 12 LastLast
Results 1 to 10 of 17
    Nov 2004
    Share ko lang sa mga naghahanap ng mahusay na mekaniko na mura maningil.
    Marikina Antipolo area
    0916-5827200
    Boy Romero
    Dati sya Chief Mechanic sa Mitsubishi then Toyota. 20years Casa Experience. Shop nya sa garage nya kaya reasonable maningil at may tawad pa. Kumpleto sa gamit from obd pati pang baba ng engine.
    Gas or Diesel From regular pms to general engine overhaul pati transmission matic or manual ginagawa nya.
    Banggitin nyo refer kayo ni Pao from tsikot ask for more discount.
    Sent from my LG-H870DS using Tapatalk
    Aug 2017
    Will try him out since I live in Marikina Thanks!
    Sent from my EVA-L19 using Tsikot Forums mobile app
    Nov 2007
    Same here. Thank you
    Jul 2016
    Good am mga ka tsikot. Ask ko lang if active pa etong number ni sir Boy Romero. I've been trying to rwach him thru this number but sadly wala ako makuha response. Need kasi ng reliable mechanic near Antipolo area. Maraming salamat sa mga sasagot.
    More power to Tsikot!
    Nov 2004
    Yes ser +63 916 582 7200 pa din number ni "tito boy" as we call him. May pajero sya gawa nung punta ko last month, around 60k daw sinisingil nung ibang several shops, baba ang makina kasi, inabot lang kay tito boy ng 20+k, personal nya kasi inspect at marami daw hindi nmn kelangan palitan, pati pagbili ng pyesa tinuturo nya kung saan mura like bestcolt in banawe etc imbes na isekreto at patungan nya encourage nya pa to canvass yun mismo customer. Pag sya pinabili nyo pyesa pati resibo ibibigay sayo pagkatapos ng trabaho.
    Kalalabas lng ng spacegear namin sa kanya, naputulan ng segunyal, pina tow ko dinala sa reputable shop na mura din maningil sa banawe dun kasi malapit, 90k ang estimate marami daw kasi papalitan. San ko nmn hagilapin yun 90k biglaan pa. Pinatow ko ulit hanggang masinag sa shop ni tito boy, nung matapos inabot lang around 20k labor materials total.
    Jul 2016
    Thank you sir Halimaw! Saan nga pal shop ni sir Boy? near masinag lng din location ko kasi.
    Aug 2017
    Quote Originally Posted by Kapitan tutan View Post
    Sa may Oliveros siya. Just went there for our Revo ATF dialysis. Charge ng labor is 3000. Drain and clean.
    Quote Originally Posted by willownavarro View Post
    labor alone is 3000? how much was the atf and ilang liters?
    Aug 2017
    Yes. Labor alone. Cause he mentioned that other mechanics just drain then put in the new oil, while he on the other hand, also cleans the strainer (? I don't remember the term) and no machine is used. ATF used was Dexron III at 170/L (10liters)
    I told him that Exalta in Banawe charges 600 for labor only. Sabi nya their techniques are different daw kasi.
    di mo nakita how the atf change was done?
Mechanic na Magaling at Mura Singil Marikina Antipolo Area
