Results 21 to 30 of 30
SiRaNeko
- Jan 2003
- 973
September 3rd, 2005 11:13 PM #22Originally Posted by jozin
September 4th, 2005 07:15 PM #23
Kim, si cody ba yun avatar mo? laki na ah at malago na ang buhok :D
September 4th, 2005 11:30 PM #24
Use Distilled drinking water not mineral water. Kaya nga we do not recommend tap water is because it contains solids.
- Aug 2005
- 6
September 5th, 2005 04:22 PM #25Thank you sir sa clarification. Any explination why distilled water is good for the engine?
September 5th, 2005 10:26 PM #26Originally Posted by jozin
Check the link http://www.928oc.org/tip/tip514.htm and read the whole article. Hope it answers your query.
September 5th, 2005 10:34 PM #27
Simply put, distilled is good because it has been distilled and the solid particles have been taken out.
Those solids can stick inside the radiator, cause scaling, and eventually foul the system.
- Jul 2005
- 83
September 6th, 2005 11:19 AM #28pag bago overhaul or top O/h makina mo,ang susunod na mangyari dyan is clogged radiator tubes.di maayos pag tangal ng head gasket mo-kinuskos then pumasok sa jacket ports.Normaly nangyayari yan pag paspasan ang trabaho ng mekaniko.
I've already experience that.maybe maybe maybe ganyan din ang nagyari.
I suggest to check all the components of your cooling system.marami kasing dahilan yong overheating problem.
- Aug 2005
- 6
September 7th, 2005 06:27 PM #29Sir Leinahtan,
Salamat sa link na bigay mo very informative. From now on I'll try saving rain water for my radiator (syempre yung malinis).
sir jeegoogs, salamat po sa input mo. Yan talaga ang cons ng nagtitipid(di kayang dalhin sa casa). Next time sana maka ipon ako ng malaki-laki para madala ang kotse ko sa casa or sa shop with reliable and dependable mechanic.
Salamat po uli.
September 9th, 2005 01:27 PM #30
if you done already lahat cnbi nla at gnon prin bka ala s timing, pg dlayed timing hirap ang engine taas temp mo,pwede rin my warp cylinder head kung matagal magcooldown at mbilis mghigh temp at high speed pwde rin improper torque and sequence ung pakbit ng head ng mekaniko
Xiaomi E-Car
