Page 2 of 2 FirstFirst 12
Results 21 to 36 of 36
    #21
    For registration na rin yung paje ko so I brought it to the Emission Testing. It failed. Black clouds of smoke in the back. The told me to bring it to a shop and have it looked at. I brought it to a calibration shop. 10 thou agad. Mga 4 hours work. (Should've brought it to Hanson na lang) They replaced delivery pump, nozzle tips, injector pump kit, oil seals. Palit ako fuel filter and air filter. They sprayed my tailpipe with water. Meron pa rin black smoke pero di na tulad dati. Sakit yata ito talaga ng 4D56 eh.
    Binaba namin idling ko to less than 1000. Siguro mga 850 to 900 yun sa gauge. Saka na lang daw namin ulit ibalik sa 1000 pag pasado na sa test.
    Brought it to the ETC again, pasado na. They stuck this pointed thing into the tailpipe and floored the pedal. Passing raw for Turbo-equipped is 3.5 units opacity. For Non-turbo-equipped 2.5 units. Mine did 1.14 units. Now rehistro na lang. Sakit talaga sa bulsa oo!
    #22
    baka pwede nalang maglagay. i don't mean to be a bad guy but its the cheapest way to pass the test.
    #23
    KCboy,
    Even if you don't mean to, bad guy ka naman talaga, eh. Hehehe. :mrgreen: Sa pic pa lang sa signature mo, bad boy na bad boy na ang dating.
    #24
    yikes! mahal yun mr pajero freak... if that's the only parts replaced.
    #25
    Mr Pajero freak,
    Did they step on your pedal to the metal? I mean did they "floor" it? According to the guidelines care of Doc D, the don't have to floor it down upon measuring...up to 3500rpm lang yata... :o
    #26
    dapat ung mismong owner ang tatapak sa gas para dahan-dahan lang..:?
    #27
    By Jan 1 of 2004 ibababa na sulfur content ng diesels natin from 0.20 to 0.05 as compliance to the Clean Air Act. Regarding sa flooring of the accelerator, siguro pag wala kang tach medyo problema ito.
    #28
    They floored the pedal to the metal as if there were no tomorrow! Di ko naman alam na may rpm pang sinusunod. Masama ba sa makina yun? The testing center im referring to is Boher near the Mandaluyong City Hall sa may "circle". Kahit naman dun sa calibration shop naaawa rin ako sa makina ko e dahil halos mawalan na ng boses yung makina sa tapak sa gas pedal talo pa yung vocalist ng Metallica. Anu ba masamang epekto nito?
    Nabasa ko nga pala sa 4x4 magazine yung may feature ng pajero history, for second-hand buyers of pajeros try to get the 2.8 or later models dahil the black smoke which is characteristic of 2.5's is one of the things they tried to correct. Mitsubishi pa ang umamin na sakit niya ito. Mukhang mahihirapan na talaga ako palagi nito magparehistro a. Pero talaga kayang wala na gaano usok ang 2.8?
    #29
    PETC's should not:
    1. Allow the owner to step on the accelerator during testing.
    2. Floor the pedal to the metal also.
    email a complaint to brtcp*dti.gov.ph if you want. they do answer.
    Doc Diesel
  10. cj is offline Verified Tsikot Member
    Join Date
    #30
    pajero freak,
    asar no? when you brought it back to the ETC again after the repairs, did they charge you another 300?
    #31
    cj, bale nung makita nilang sobra yung usok sinabihan muna akong ipagawa ko. Sayang daw kasi pera kung siguradong bagsak rin naman. Kaya yung pangalawang beses lang naman ako bayad ng 300
  12. cj is offline Verified Tsikot Member
    Join Date
    #32
    paj, salamat sa reply.
    ibig nila sabihin kung hindi pala grabe ang usok at tinuloy ang testing tapos sumabit, bayad ulit? walastek!
    #33
    kc maglagay nalang po tayo. pag nakakita me ng taga test center na d tumatanggap ng lagay, dun me maniniwala na lilinis na ang air ng pilipinass!!!!!!!!
    #34
    dapat binaba muna nila ang sulfur content saka inayos ang diesl fuel bago sila nag clean air act na yan! !*#$%^ talaga! :evil:
    #35
    Pwede bang ikabit yung monster tach ko sa rx7 ko sa c240 ko? :D Para pag sinita ako sa daan for smoke belching ay makita kong hanggang 3500rpm lang at saan ba ikinakabit sa diesel wla namng ignition coil or iba ba ang tach ng diesel?
    #36
    iba ang tach ng diesel pre eh.
    DEYM hehhhehe
LTO Emissions Test & Calibration
