Page 1 of 2 12 LastLast
Results 1 to 20 of 21
    Oct 2009
    guys low rpm pag naka aircon my mechanic changed the serbo and even the air hose filter pero ganun pa din baba ng minor ko.. adjusted several times pero ganun pa din eh.. what could be the prob? but he noticed though that my intake manifold eh mahina ang higop???
    What's your car's make and model? If the aircon is off, does your engine behave normally? If so, have your aircon system checked by a good aircon shop. It may be putting too much load on the engine when turned on (compressor in need of an overhaul, failing aux fan, dirty condenser, etc).
    Oct 2009
    Quote Originally Posted by CivicVTi View Post
    civic esi po, yup when my ac is off nasa 700 po ang rpm ko. do you have any recommended shop around qc? thanks
    You can visit Abacus aircon shop along West Avenue QC, its near the gate entrance of Philam Homes. That's where I usually have my aircon fixed if needed. The owner's name is Rene Borlongan, most of the time he attends to his clients himself and instructs his mechanics what needs to be done. Good service and reasonable fees.
    Oct 2009
    Hi, thanks for your suggestion, but two mechanics has already checked my car pero the problem still occurs. sobrang baba ng idle ko if naka on AC nginig na nginig namatayan na ko madalas. kaya di muna ako nag aaircon, they said that ac has nothing to do with my prob... kaya idk na talaga ive spent a lot for changing parts pero still ganun pa din. haayz!
    tama si civicvti pwedeng sa aircon system maaaring sobrang sikip ng belt, over pressure ang system, or busted ang compressor kaya sobra ang load sa engine, or cleaning ng intake manifold ,since sabi mo nag change na ng servo
    Oct 2009
    thanks ill be sure to check civicvti suggested place.. if di pa rin. i guess sell ko na lang tong unit
  8. #8
    Similar problem happened to my 4AFE. Wala raw kuryente dun sa idle. Ewan, medyo mahirap i-explain. Not sure what that part is. So naglatag siya nang bagong wire to aircon compressor. Prior to that, rough idling ako, parang mamamatayan na. Then when I turn off the aircon, balik sa normal idling. Tapos hindi agad nag-on ang compressor nung aircon.
    Anyway, dinala ko sa Cool Attack sa Ortigas Center... ayos na.
    Oct 2009
    Quote Originally Posted by paolorenzo View Post
    thanks! anu ba normal rpm nio pag naka on ang ac? and w/o ac?
    Oct 2009
    CivicVTI, I just went to the abacus earlier and they said that they dont know how to fix my problem! id even told them that my friend used to have the same prob and they are the one who fixed their prob. but they said that they that don't have toold for my problem dalin ko daw sa mekaniko... haayz
    Jun 2010
    sure ka ok ang servo na ipinalit mo? brand new or surplus?
    May 2009
    how about the vacuum hose connecting the intake manifold to the brake booster? did you check it?
    parang may vacuum leak somewhere....
    have you had your IAC checked and cleaned? its the one that controls the idle rpm, they just clean it with sensor friendly carb cleaner.
    Quote Originally Posted by tonzi View Post
    Did you speak with Rene, the owner? Did they inspect your aircon system? What specifically did they do, if I may ask. As of now, I can only guess that the problem lies within the engine and not the aircon system. For that I usually go to Sprint in Banawe. If you're coming from Quiapo along Quezon Avenue, turn right at Banawe. The first corner to your right, that's where they are located. You may call them first at 711-3535 to describe the problem.
    I hope this can help. Update us soon.
    Oct 2009
    Quote Originally Posted by ben_david19 View Post
    naka five times na po ako nagpalit ng servo all of them are surplus pero out of those five? imposible naman po na wlang gumana dun??
    Quote Originally Posted by miked View Post
    wala naman pong leak... ok lahat except for the rpm drops when ac is on.
    yep I talked to mr Rene, he saw my car but he didn't check it coz he told me that this isn't the place for my problem. sabi nya agad servo yan and aircon has nothing to do with it, his boy's couldnt fix it, aircon lang daw. they dont have idling kit... that's exactly what he said.
    galing ako stage 1 motorworks in araneta. they said that have my car checked by an aircon specialist coz hindi daw sa computer box ang problem..., they refer aves aircon specialist in speaker perez in qc... so nagpunta ako dun kaso lunch time, so dumeretso na ko abacus pero yun ang sabi di daw sa ac.. then I went somwhere in banawe i forgot the store though its near in retiro. they are the ones who replaced by servo five times but prob still occurs so pinababalik nila ako tomorrow to check my computer box, pero while on my way home I accidentally stopped at this shop in cordillera near banawe. I asked them if they could fix my problem... same thing adjust and changed servo but andun pa din prob. so ginawa nila they replaced my computer box with another comp box. pero ganun pa din. so wala sa comp box ang problem...... nakaka frustrate na po talaga. walang nakakagawa ng problema ko huhu di ako makapag aircon
    Take it to Sprint bro, have them take a look at it and tell the mechanics there what the other shops told you. I once had a Honda Civic VTi (hence my username here) and whenever I had engine problems, they always found a solution.
    My second recommendation would be to visit Speedyfix at Shaw Blvd. (http://www.speedyfixph.com/) Maybe they can help you find the answer. Migs, the owner, is very knowledgeable...but he's out of the country right now. He'll be back next week Monday (I called earlier today). Their head mechanic is on duty though.
    Another shop you can go to is SpeedLab along Quezon Avenue, its across Pegasus. I think they can also troubleshoot your problems.
    Double post.
    Oct 2009
    Double post.
    thank you so much, i'll be sure to visit those said places, I hope one of them could finally fix my problem. pinag papasahan kasi ako ng mga mekaniko hehe
    Nov 2007
    sir ano feedback ng aircon mo?
    Jan 2010
    Sana magreply sya kung sino nakaayos ng problema nya...
Low rpm sa aircon
